Question about Microwave Ovens
LSS ultrasonic cleaner takes 6 hours to heat while when we initially bought it less than a year ago it would heat up to 60 degrees centigrade within 2 hours. Mfr. Model# 32V120
4 Suggested Answers
  • 140 Answers
SOURCE: GE less than 2 year old microwave runs, doesn't heat
The problem you are having is that the magnetron that actually does the heating has gone bad. The fact that everthing works fine rules out any type of bad fuse since there is only one 15amp ceramic fuse in most cases in the unit itself. The magnetron is located behind the control panel on top and has some cooling fins on it. Replacing it if you are a do-it-yourselfer is pretty easy provided you can find one at local electronic supplier or on the internet such as www.mwoparts.com if you would like to see what it looks like. It is held in place with typically 4 screws. It has two to three terminals depending on make and model and age. With everything unplugged it comes off easily enough with no desoldering or soldering to do. There is a High Voltage Capacitor and Diode that could be bad also, but without being able to check it in person it would be difficult for me to tell that they are. In my experience the magnetron is the first thing I replace and have never replaced a capacitor or high voltage diode in the past 20 years. Good luck and God bless.
Posted on Jan 23, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Built in oven takes hours to reach desired degrees set.
There may be a problem with either the door seal or the thermostat.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you can download GE owner's manuals and installation instructions here in case you don't have yours.
Once you look it over, if you still have a problem,
GE Customer Service is here and they should be able to help you check it or send service if you have a problem.
Posted on Feb 08, 2009
caroldon
  • 17129 Answers
SOURCE: i have a whirlpool fridge freezer (model 20rud4).
it is possible that your fridge has developed a snag in its cooling system. what could be done from your end will be to first of all switch off the fridge for at least 8 hours. allow it to totally defrost. then switch on to see if the cooling returns. if so reduce the thermostat to 7 degrees and check. if the cooling returns then you will need to check for frosting inside due to failure of the thermostat or the auto defroster. if there is still no cooling then your gas has leaked, failureof the compressor, failue of the valves in the compressor could be suspected. Probe with these inputs. Good day
Posted on Jul 13, 2010
Temperature in degree centigrade at 10 power level
It does not work that way. The microwave OVEN generates (electromagnetic) microwaves that are absorbed by the molecules of the food in the oven, the container and the air.
The absorption rate depends on the molecular composition. After enough microwave energy is absorbed the overall temperature increases and the food is warmed, heated or cooked. If your mixture is inhomogeneous some parts absorb more energy while other absorb less and you can have hot spots.
The power level by itself won't give you an indication of the temperature because you need to know the time that the power has been applied. In simple terms Energy =time*power. The temperature reached is somewhat proportional to the energy, that makes it dependent on the time and the power.
Dec 22, 2013 | Haier MWM0925T 0.9 cu. ft. Microwave With...
Tip
MICROWAVE POWER TEST Hi Everyone, In this tip I will show you how to easily test...
Hi Everyone,
In this tip I will show you how to easily test your Microwaves power. If it is sufficient, or if it is not heating effectively anymore.
Non heating Microwaves are a common issue, and the most likely component that is faulty is the Magnetron - These days Magnetron's are quite expensive (usually about 50% the price of a new Entry Level Microwave). Low heating could mean a Magnetron becoming faulty (unlikely, as a Magnetron either works, or it doesn't work)
Tools required: A Normal Glass (Heat-resistant, in other words Microwave friendly), Water (Room Temperature) , a Centigrade Thermometer (Can get this at any Pharmacy)
Procedure:
1) Fill a glass with approx. 125 ml water. Use water at room temperature (from the tap), avoid using refrigerated water as this will work against the test we are doing.
2) Measure the initial temperature of the water with the thermometer (It should be between approx. 10 & 20 degrees).
3) Place the glass with the water about 2 cm away from the center of the Microwave Oven plate.
4) Heat the water at full power (The highest setting possible on your Microwave) for 70 seconds.
5) Stir the water (For 5 - 8 sec).
6) Measure the final water temperature with a thermometer.
7) If the increase is 45 degrees or more, then your microwave is heating sufficiently, if not it could mean replacing the Magnetron, or purchasing a new Microwave.
I hope this guide as helped you. If it has, please rate it accordingly.
on Apr 23, 2011 | Microwave Ovens
Microwave now takes ~2x longer to heat up and is steaming up inside
Place a 1/2 litre of water in a plastic microwaveable container. Record its temperature and place it in the microwave. Microwave on full power for 1 minute. Leave for 30 seconds and measure the temperature again.
If the temperature rise is at least 10 degrees Centigrade, the magnetron is fine.
Mar 02, 2011 | Whirlpool Microwave Ovens
Wattage Power
Unfortunately, the old owner's manual doesn't say, but you can do a test to see what its heating power is:
MICROWAVE HEATING POWER TEST
The following test will provide a suitably accurate measurement of the output power of any microwave oven. Variations or errors in performing this test will produce uncertain results. If the line voltage (from the electrical outlet) is low, the magnetron output will be correspondingly low.
Equipment needed:
- Microwave safe container with 1000 mL (1 Liter) gradation.
- Fahrenheit or centigrade thermometer
Procedure:
Pour exactly 1000 mL (1 Liter) of cool tap water into the container. Using the thermometer, stir the water, then measure and record the temperature. For accurate results the water should be about 60 degrees F (20 degrees C).
Place the container on the center of the oven cooking shelf (do not leave the thermometer in the container and remove any metal racks), and heat the water (at full power) for 63 seconds. Use the second hand of a watch, not the oven timer.
After the heating time is completed, immediately remove the container, stir the water, re-measure and record the temperature of the heated water.
Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or by 70 if you're using a centigrade thermometer.
Apr 28, 2010 | Hotpoint RVM1435 Microwave Oven
What is the wattage?
Oddly, the owner's manual doesn't say.
You can contact GE customer service here, or if it's working properly, here's a test that will tell you how much output power it has:
Equipment needed:
Procedure:
Apr 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hotpoint microwave oven, countertop, model RE964. How many watts is it?
The owner's manual (which you can download here) does not say, but most of their ovens from that era were 700 watts.
There is a way to check:
Equipment needed:
Procedure:
Jun 06, 2009 | Microwave Ovens
I have a microwave peanut brittle recipe but it burns, someone told me that I need to calibrate my microwave. How do I do that?
Equipment needed:
Procedure:
Dec 15, 2008 | Microwave Ovens
1) What's the expectect temp range for 1L water, for GE load test for 1KW ovens? 2)Why didn't my brand new oven come with a repair/maintenance packet like my old one did? Tom
1) MICROWAVE HEATING POWER TEST
Equipment needed:
Procedure:
2) If it's not
hidden either behind the grille or control panel, they may have left it out as a cost-savings measure.
Nov 26, 2008 | Microwave Ovens
My whirlpool microwave heats up the top cover / outer metal casing. It seems to get hotter and hotter, even though the food inside may not be all that hot. Eventually it may even stop running the...
If the cooling fan is not running, then that definitely needs to be addressed to prevent magnetron damage.
-.htmThere should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
-.htmYou can usually find helpful exploded view diagrams and order parts by entering your full model number here.
It might be useful to first do a standard heat test.
-.htmMICROWAVE HEATING POWER TEST
Equipment needed:
Procedure:
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or 70 if you're using a centigrade thermometer.
-.htmWe're happy to help and we appreciate your thoughtful rating of our answer.
Jul 12, 2008 | Whirlpool Microwave Ovens
How can you check to see if your microwave oven is working at full power
Equipment needed:
Procedure:
Jul 06, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
