Had a paper jam yesterday and after removing jam screen is staing "over heat" this a a xerox workcentre pro412
    Scholar:
  • 136 Answers
"Overheat" on this machine occurs when the fuser element has over heated usually caused in jams because the paper BLOCKS the heat sensor.
Shut off your machine, wait 30 minutes to let cool off or an Hour if you have more time then re-start your copier again, if the Fuser isn't damaged the machine will reset itself. If the Problem presist then you accidentally Damaged the Fuser. If you need one Ihave those available and if your in the Connecticut area you can place a service call and we will be happy to do it.
Posted on Jul 24, 2009
  • copiersplusw
    copiersplusw Jul 24, 2009
    Shut off your machine, wait 30 minutes to let cool off or an Hour if you have more time then re-start your copier again, if the Fuser isn't damaged the machine will reset itself. If the Problem presist then you accidentally Damaged the Fuser. If you need one I have those available and if your in the Connecticut area you can place a service call and we will be happy to do it.
I need need a picture on how to remove a paper jam in xerox 4118 machine right now please
Well open the printer where you can(the closest point to the jammed paper) attempt to remove the jam by attempting to pull the Jamed paper in the direction it would normally exit the machine.thats about as far as I can get you with the information I have--Good Luck.
Feb 01, 2013 | Xerox WorkCentre 4118 Network Kit - 1 x...
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
Xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Take care
Jul 19, 2010 | Xerox WorkCentre M15i Laser Printer
I get frequent paper jams in the back of my Xerox. The paper gets completely folded up back there, like an origami. what can I do?
Replace the fuser. The heat rolls teflon surface is wearing out and the paper is sticking to the heat roller.
Mar 21, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
My workcentre Pro 416 shows a jam, i have removed all jams that i could see. However it shows clear jam, and has 19 to dos on the screen, like open door, clean jam, close door, etc.. Is there a major reset...
On this 416 machine, there is one place you cannot see a jam.
Looking at the machine the right side doors need to be opened.
The lower trays feed paper and need to go up the by pass feeder area.
Just lower and behind the by-pass feeder the paper can get stuck, and you cannot see it.
If you try to push a card stock up from the bottom, the paper can be pushed out.
The other area is at the fuser. If the switch is worn it will not drop back into position. The tip of the switch wears and breaks off.
It is rare a sensor goes out on this machine, besides the fuser sensor. Each paper feed head needs to be checked to see if the paper sensors are bad.
Not seeing the machine, call Xerox for service repair if not resolved.
Jul 15, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
I have xerox workcentre xd105f, can't make copies, paper jamed and letter P on display
to remedy the P display error remove the paper tray and take any paper from under the tray and between the rollers, clean the rollers with alcohol or an acetone solution to remove paper dust and paper debris, refit the paper tray with the paper pushed below the tabs on the tray ensuring that the correct paper size is shown, IE: ltr ltr-r etc.
power the unit off and on and you should be back in business.
If this remedies the problem please rate the solution accordingly
thanks
Derek
Jun 19, 2009 | Xerox WorkCentre XD105F Laser Printer
I have xerox workcentre xd105f, can't make copies,paper jam
P will flash on the screen when the paper tray is empty, paper misfeeds or the paper tray door isn't closed all the way. Make sure both (if you have 2 paper trays) are loaded, that the paper isn't folder and wrinkled, and ensure that the tray doors are closed firmly. Then hit start on the workcentre to continue any unfinished jobs.
Jun 19, 2009 | Office Equipment & Supplies
Xerox Workcentre 24- Paper jam in the fuser
Shut down. Unplug!!! Remove fuser to remove jam. Fuser may be or be going bad.
Apr 22, 2009 | Xerox WorkCentre M-24 Color Copier
Xerox xd100 copier
Sounds like 2 different things going on.
The slow warm up is normally the toner cartridge is almost out of ink but not reporting it. It is trying to set up but there is not enough ink to do so.
The jams, if the machine is making it into the machine but not exiting, then you most likely have a broken gear on the end of the heat roller in the fuser
Dec 07, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
48 people viewed this question
k24674
jasbo
jasbo
