Question about Dryers
The blue wire at the very front of the heating element keeps burning. What is causing it to burn?
  • Dryers Master
  • 8,220 Answers
Loose connection can cause this make sure its tight. If it keeps doing it change the thermostat on the blower.
Posted on Jan 04, 2017
  • 198 Answers
SOURCE: ONE OFTHE CONTACTS KEEPS BURNING AT ELEMENT
You will have to replace the heat element, because the male terminal is burnt, which causes too much heat at the connection, and causes the wire to burn. If you can clean the terminal to where its shiny it may work otherwise replace the element
Posted on Jan 19, 2009
farfield
  • 462 Answers
SOURCE: Brand new dryer heating element burned out.
If air flow is restricted this can cause it. Or if your voltage is high or if you have received an element that has been stretched and is loose this could cause it. You say immediate and how long in loads or time is this? Are you sure the element still has full voltage (220V aprox) to the element?
Posted on Mar 16, 2009
  • 323 Answers
SOURCE: Wire to heating element burns in two at connection
Did it just start burning out on its own, or have you recently changed the element or the wire to the element?
It sounds like the crimp isn't nearly heavy enough for the wire. If the wire isn't burned, and the element is the right one, then either the wire is not a heavy enough guage or the crimp is too light weight for that connection.
Dryers are 240 volts and there's a lot of amps going through that connector. If it is not the same as the original, buy a heavy duty crimp ring from an electrical supply house for that guage of wire or at a Home Depot or Lowes.
Let us know if that's not the case.
Sirwriter
Posted on May 13, 2009
localwonder
  • 6784 Answers
SOURCE: Not heating
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Concerning the wire issue. this is caused by a faulty wiring harness. replace this wire harness asap.
Posted on Jun 18, 2009
The_lRipper
  • 116 Answers
SOURCE: I have a Maytag
Okay have you replaced the wire with with the correct one? If the wire gauge is wrong it will do every time next you need a volt meter with a buzzer sound maker on it test your thermostat and hi limit thermostat if it makes a noise when testing its working. Only thing that would cause that wire to keep burning are those options and if all checks out okay then its faulty wiring which is grounding out somewhere which is a pain to trace and if you might not find the bad wire had a few of these with these problems and I ended up junking them big fire hazard sorry for the problem.
Posted on Jan 06, 2011
Model 790.96009601 I replaced the heating element that burned out. New heating element does not work.
The replacement heating element could be defective, not burned out. Also, the replacement element could have been installed incorrectly.
Oct 29, 2014 | Kitchen Ranges
I have a Maytag Electric Dryer model #MDE5500AYW that will not heat up. When I opened the front and looked at the heating element, I noticed that the wire attached to the heating element (a black wire)...
Jan 06, 2011 | Maytag MDE5500AYW Electric Dryer
Not heating
If your dryer is not getting any heat, you need to make sure there is nothing blocking the front of the dryer. Air flow is key to efficient drying.
  • Check the heating element, burner operation, ignitor, thermal fuse and the wiring (power cord).
  • Visually inspect your heating element for any broken or burned areas. The heating element is a coil made from a nickel-chrome alloy, called nichrome.
  • Check Burner, if it is working the flame should be clean and blue.
Good Luck and have a nice day
Rating the solution is highly appreciated
Jun 15, 2010 | Roper Dryers
Dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not heating
you have a dead short somewhere or someone monkeyed around the dryer to repair it
Jun 18, 2009 | Amana DLE330RAW Electric Dryer
Put new heating element in dryer and still no heat but works in all other aspects.
The most likely cause is one of the temperature control thermostats or the overheat safety thermostat. To check these, disconnect the wires and check them with an ohm meter. They should all be closed... Very close to Zero Ohms. You can use a test light on plain old electro-mechanical thermostats but be careful using them on electronic temp sensing thermostats. They could cause an overcurrent condition and burn out the thermostat if it's not already burned out.
If the thermostats are good, there is usually a safety switch in the motor to keep the element from heating if the motor is not running. This switch may be defective and not allowing current to the heating elements.
Hope this helps.
Jun 15, 2009 | Maytag SDE5401AYW Electric Dryer
F1 ERROR
This is a water heating error.
There are a few possible causes:
  1. Bad heating element
  2. Bad connection of wires to heating element
  3. Bad control board
Be sure that water hookup for dishwasher is hot water.
Unplug electrical connection to unit.
Remove front bottom cover.
Check wires to heating element for burning and that they are connected properly.
You may need a multimeter to check power to element and to help trace the circuit if necessary.
Apr 15, 2009 | Asko D1776 Stainless Steel Built-in...
Dec 18, 2008 | Roper REX4634KQ Electric Dryer
Admiral Dryer (Model # ADE7005AYW) wire connector burning causing no heat
I had the same problem with my dryer. Fixed it with high temp wire (875 F) and end connectors rated for the same temperature. Make good connections between the wire and the connectors because if they are poor they will heat up as well. Sometimes the thermostat will cause this problem as well or an older heating element that is going bad.
Nov 05, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
