Pulled the bin out to empty the paper. slid it back in but no power Can't get it to turn back on.?
    Top Expert:
  • Office Equip... Master
  • 40,304 Answers
The bin is not actuating the interlock inside.
Posted on Jan 03, 2017
There is an interlock that prevents the shredder from operating without the bin in place. Something may be jammed in the interlock or the bin may not be closing the interlock as it is slid in place.
Feb 13, 2015 | Shredder Office Equipment & Supplies
How to output bin empty ?
  1. The output bin may be full. Empty the output bin. Printing resumes automatically.
  2. Take a close look at the flaps hanging out the exit of the printer. They should move up and down freely. If one of them is stuck up, broken or dislodged, then a bin full error is displayed.
  3. Open rear exit tray and power on the printer. If the printer comes to a Ready state, close rear tray and try printing.
  4. Clean the paper path below the toner area and exit assembly at the back of the printer. Ensure there is no pieces of paper stuck in the paper path of the printer.
Jan 20, 2015 | HP LaserJet 5200 Printer
My shredder worked fine but now when I turn on it does not stop running and does not shred paper ?
Most shredders will have a shred and a reverse setting. Is it running in reverse? Has the bin been emptied? With the power off, you can remove the bin and manually pull excess shredded paper jammed in the cutting heads -watch out, sharp metal . Once cleared run single sheets for the first minute to help clear rollers.
Jan 05, 2015 | Shredder Office Equipment & Supplies
How do you remove the bin to empty the shredded paper?
Most bins pull out. However, if yours is stuck try using a stiff ruler between the top of the bin and front of shredder. Use the ruler to push down the shredding as you pull the drawer.
Oct 15, 2014 | Office Equipment & Supplies
Shredder bin full
Most models: 1) unplug, 2) put something down to collect paper bits, 3) lift up the shredder top unit off the bin, 4) empty the bin, 5) try and pull out any paper from the shredder top using tweezers - first remove paper that has not fed through by pulling it back out.
Often if the bin is overfull the shredder gets clogged and won't work or beeps. When unplugged, you have to carefully remove all the bits of paper from the teeth to unjam the two rows of teeth. Remedy is to frequently empty the bin.
Jul 29, 2014 | Office Equipment & Supplies
Unplug the unit from the power source. Open the front of the machine to expose the bin area. Remove the paper bin and look for any signs of paper trapped at or around the blade area. Pull or brush away any debris that may be in that area. Wipe around the sensor with a dry loin cloth or use a can of compressed air for tighter areas. Replace the bin and close the front. Reconnect the power and the Bin Full light should go out.
Feb 20, 2012 | Gbc GDX1813 Shredder
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
The bin on my royal cross cut paper shredder will not open . It is full and needs to be emptied. It seems to be stuck near the top. If I pull any harder I am afraid the hard plastic will crack.
Yes it is probably "over-full".... you will just have to try to somehow get it open a little and start to fish out the paper without breaking the waste has to be emptied more frequently, there is no "bin-full" indicator.
Dec 28, 2010 | Royal Office Equipment & Supplies
How to empty paper bin in ativa md400?
I encountered the same problem today. I called the support number and they said to simply pull in a downward motion. After brute force, I budged the container enough to start pulling paper out of it. I emptied three grocery bags of shredding by the time I fully emptied the bin. The problem here is that the machine lets you over-fill the bin, thus making it difficult to remove. So check it more often.
Dec 03, 2010 | Office Equipment & Supplies
29 people viewed this question
