Screen goes into split screen without requesting
Like to turn off split screen can I do that
Marca
  • 5 Answers
SOURCE: black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Posted on Nov 25, 2007
  • 4 Answers
SOURCE: screen turns black
problem with the inverter chek it
Posted on Feb 10, 2009
  • 12 Answers
SOURCE: cannot disable split screen (DIST dynamic gamma)
the way i solved it is by holding down the menu and the volume(-) and the disabling the dis. That worked for me so you should try it.
Posted on Jun 21, 2009
byteguy
  • 2229 Answers
SOURCE: My monitor showes for a split second then goes black
First, can you attach another monitor to the computer to check to see if it works?
If it does, then your monitor is going bad. Possibly the power supply.
If a second monitor acts the same way, then it's your video card.
Posted on Dec 10, 2009
  • 33294 Answers
SOURCE: Hitachi 55PMA550 TV Turns on (power light goes
Could be a failing power supply.
Posted on Oct 15, 2014
How to fix black screen on television?
Inverter board is responsible for the backlighting.
Oct 28, 2015 | LG Televison & Video
Picture has hourglass look and has split screen picture hourglass comes and goes but split screen is continual
If hour glass on conventional set it is either pincussion circuit or power supply---by split screen if you mean folded over top to bottom in the middle that is in the same areas.
Apr 06, 2012 | ESA EF427E TV
Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
May 18, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Cannot disable split screen (DIST dynamic gamma)
May 16, 2009 | JVC LT-26X575 26 in. LCD HDTV
Security
If it is configured to lock the screen it can yes if you don't know the code try 0000 if that doesn't work reboot phone and before the screen locks type 277634#*# it will open a hidden engineer's menu and you can choose master rest phone and it will set all settings and codes to default and turn the screen lock off for you.
Jan 08, 2009 | LG Vu CU920 Cellular Phone
When I plug my mp3 player into the Usb port, the screen goes to the connected screen for a split second. Then it goes back to the normal screen. The mps player will continue to go back and forth betwwen...
When I plug my mp3 player into the Usb port, the screen goes to the connected screen for a split second. Then it goes back to the normal screen. The mps player will continue to go back and forth betwwen the two not really connected or playing untill I unplug the cord then its normal.
Aug 27, 2008 | Audio Players & Recorders
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Screen turns black
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
