Question about Toys
  • 575 Answers
Low on fluid or a bad solenoid.
Posted on Jan 03, 2017
Why wont my bobcat lift bucket
Hi John:
This is in the toys category.
If you're like me, and it is a real working bobcat, I understand. All of my machines are toys.
= So, assuming this is a really machine, you'll be dealing with a hydraulic problem, and if it were me, I'd be trouble shooting sort of like this:
WORK SAFE - All hydraulics lowered, machine off.
1) Check hydraulic tank fluid level.
2) Look under machine for any signs of leakage
3) Check all hoses, cylinders, and concealed spaces for signs of leakage.
4) Check pump for signs of leakage, make sure drive is engaged.
Please reply to this post as a comment and we'll carry on unless you've spotted the problem.
Nov 30, 2015 | Toys
How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Sep 23, 2015 | Toys
I have a s175 bobcat and the bucket will not stay knurled when i tilt the bucket up it just slowly dumps it
This is because of oil leaking back out of the hydraulic cylinders. It is ether the cylinders themselves leaking internally or the control valve leaking. Also check to make sure the control valve linkage is not sticking and holding the valve off neutral position
May 31, 2015 | Washing Machines
My Bobcat 742 Loader will move forward and reverse but the bucket will not raise or tilt.
You more than likely have issues with the hydralic system portion that supports the boom and bucket
Jan 21, 2015 | Toys
Bobcat 533 tilt and lift not working
The hydroloic pump that operates the lift is failing. The drive operates on a separate pump so that pump is good. Find the pump that the lift rams hoses go to. That's the one you need to examine. Check all connections. Electrical, hydrolic lines, vacume hoses... everything. If all that checks out, then you need to have the pump rebuilt or replaced
Nov 10, 2017 | Cars & Trucks
I get code 32-49 Lift actuator short to ground.Does this mean I have to replace the actuator?
Switch lift and tilt actuator plugs and see if problem changes to tilt actuator fault. If so yes replace lift actuator and calibrate actuators.
Feb 08, 2010 | RTO Construction Bobcat by Woody Click
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
