Screen jumps by itslf - Computers & Internet
Wireless charger not charging phone
Normally blinking means charging and the light will stay/keep ON once it completed charging.
May 15, 2014 | Wireless Solutions Plus Wireless Solutions...
I brot nokia c6 1monthago bt nw it gt swtchoff itslf n menu dont wrk wen i clik on it systm eror aprrwat cn i do
Sometimes, its happens when you install any unauthorized apps or if your phone hitted with something at this case contact with any nearest nokia customar centre
thanks
Sep 29, 2011 | Nokia Lands Phones
Fuel gauge is stuck on full, what do i do to fix it
try changing the feul pump sending unit or the gauge itslf
Apr 23, 2011 | 1996 Dodge Dakota
Have coolant leeking on passanger side windshield fogs up even with the car sitting in the drive way. I believe the heater core is located on the passanger side back by the fire wall just would like to...
Hmmm.... That might a condensation wter from ur A/C or as u have said ur coolant. The liquid coming out from ur a/c and heater housing, the problem would be the DRAiN hose thats been blocked! Look down in that area where this liquid coming from, a HOSE will be in there and going thru the floor area, either the drain hose is blocked or it dislocated itslf and didn't pass thru the floor drainage hole! Check on that! Taah!
Nov 17, 2010 | 1999 Saturn SL
Turns over but wont start 2002 nissan altima
begin troubleshoot your car to the fuel system, does the fuel goes to fuel rail, check the fuel pressure, does it pressurized? if no pressure check the fuel pump or fuel itslf,check the fuse of injectors and coils, also the coil ground, if all ok, try to remove one spark plug wire and observe the high voltage drop while crunking the engine, if spark is ok and fuel is ok, it engine timing problem, if no spark check ignition system voltage on and grounding, if voltage ok, but no spark, check the crankshop position sensor and camshaft sensor.
Aug 05, 2010 | 2002 Nissan Altima
I hv downloaded yahoo msngr version10but not able to receve calls
there may be a problem with the yahoo messenger installation or it might not be installed properly...
first you uninstall the yahoo messenger from your pc completely...
then RESTART the computer...
then again install the yahoo messenger....you can redownload it from the website :
http://in.messenger.yahoo.com/download/
from the above link download it and then install...
these are usually installation problems...
it will surely help...try it...
and plz dont forget to vote for me and give me ratings...
thanks....
Jul 11, 2010 | Yahoo Messenger
I need help my screen jumping up and down i have an apple compute
ur screen is jumping up and down because of lack of settings.
open sittings and adjust the magnetic settings so that jumping and bubbling of screen make it in control...
Mar 28, 2009 | IBM P 202 21" CRT Monitor
Sony rear projection tv keeps shuttin off
If you have correctly seated the lamp door, then check the door itslf near the screw that tightens it down. There is a little tip that sticks through a hole to engage a safety switch. Either the tip has broken off or the safety switch has gotten damaged.
Oct 30, 2008 | Sony KDF46E2000 46" Projection HDTV
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
