I have a blue box on top of the tv that says swipe down from top to exit full screen then it says ok I don't have a touchscreen how do I get it off
5 Suggested Answers
  • 2920 Answers
SOURCE: How to repair a samsung rear projection tv
your power supply is getting weak
Posted on Aug 25, 2008
SOURCE: set top box - service list changed
yo, try this, i just bought the same STB and had the same problem. So far this has fixed it (fingers crossed).
Posted on Dec 23, 2008
SOURCE: sanyo tv when switch on has a blue box with
my sanyo tele isnt switching on, there is a white light flashing, but nothing is switching on?
Posted on Mar 05, 2011
  • 1552 Answers
SOURCE: Our screen turns blue and goes to new devices input. We have nothing else connected to tv except Brighthouse cable box. If we push the exit button on the tv remote it then goes to showing a cable box
Your TV probably has multiple "inputs" (coax, HDMI, component, et cetera). Use the "input" (or "source") button on your TV to cycle through all those available "input" streams.
If you select "coax", and there is *NO* coax cable connected to the back of the TV, you *WILL* see the "blue-screen". Select a different source that is "active".
Posted on Feb 24, 2015
The message swipe down from the top to exit full scree ok is constantly on the tv screen with my Mxqpro tv box and I cannot highlight it with the curser to remove it, how do I remove?
Try a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 26, 2016 | Televison & Video
I have a kindle 4th gen touchscreen that seems to b stuck in german, how do i reset to english
Swipe down from the top of the screen and tap 'mehr'
tap anywhere you see 'sprache; zunge' then ta again on where you see 'sprache; zunge' then select your prefered language; English on the list and it automatically changes
Feb 25, 2015 | Tablets & eReaders
Coby kyros MID 7022 wont unlock main screen....swiping only meets halfway then screen goes
ok try the reset button plug the power cord before you start. look where is the reset and use a small point toothpick .
Nov 03, 2013 | Coby Kyros 7" Touchscreen Tablet
Can't connect Samsung GT-S5620 to internet
Samsung phones have a hidden settings screen at the top of the screen on the normal screen
pull down the top of the screen by placing finger at top of screen and swipe down
and expand the hidden settings you will than see wi-fi , location, sound,screen rotation, blue tooth, put finger on right top of screen and swipe left you then should see
Mobile Data at left top of screen
put finger on mobile data and it should turn on mobile data
Apr 25, 2017 | Cell Phones
Brother mfc-6490cw lcd screen shows no display (just the backlight is on)
Procedure1: Changing the LCD Contrast setting
  1. Press Menu.
  2. Press the Up or Down Arrow key to choose General Setup.
  3. Press OK. (For touchscreen models, skip this step.)
  4. Press the Up or Down Arrow key to choose LCD Settings.
  5. Press OK. (For touchscreen models, skip this step.)
  6. Choose LCD Contrast and then choose Light, Med, or Dark.
  7. Press OK. (For touchscreen models, skip this step.)
  8. Press Stop/Exit.
Procedure 2: Changing the Backlight Brightness setting
(This option may not appear depending on the model of your Brother machine.)
  1. Press Menu.
  6. Choose Backlight.
  7. Do one of the following (The menu varies on your model.):
    • Choose Light, Med, or Dark.
    • Press the Left Arrow key to make the backlight darker or press the Right Arrow key to make the backlight lighter.
  8. Press OK. (For touch screen models, skip this step.)
  9. Press Stop/Exit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 28, 2011 | Brother MFC 6490CW InkJet Printer
My TV seem to be on wide screen and it shows half the picture, how do I set it up on full screen? No other material is connected to the TV
If your TV displays a black box type shade on the screen means that your TV may be set to "Text" mode. To clear the screen, select "Caption Off mode".
To do this, press "MENU" button to display menu functions on the screen. Press "channel up or channel down" button to select the function "CAPTION". Press "Volume Up or Volume Down " button to select the mode you wish. There are five modes that you can select; Caption-Off; Caption-C1; Caption-C2; Caption-T1 and Caption-T2. As no other matereial is connected to your TV, you just select "CAPTION-OFF". When done press the Menu button again to exit menu display. Ok.
Oct 22, 2010 | Durabrand DWT1304 13" TV
Where can i get the channel list for my eurovox EX5100 pvr blue
Hi, Please try the below mentioned steps: AUTO SORT OFF B4 U MANUAL SCAN A CHANNEL/S: Go into Menu / Installation / Fast Install and press OK (enter pin) Now press the red button on the remote for advanced install Scroll down the options and turn Fav Sort off then press exit (do not press OK) if you press OK all channel order will get sorted back to the default order MANUAL SCAN ALL CHANNEL?S: follow AUTO SORT OFF After you press exit you get a list of frequency?s press red button (update) to update all channels MANUAL SCAN ONE CHANNEL: On the channel that?s scramble press the info button twice and make a note of the frequency at the top left, now follow AUTO SORT OFF when u press exit u get a list of frequency?s scroll down till you get to the frequency you made a note of and press ok to tick the box then press blue button for manual scan a factory reset on the box m8 then rescan for chanells then leave your box on sly sports 1 to update
May 19, 2010 | Computers & Internet
Cannot record and it has wiped off all previous recordings, maybe something I pressed but i cannot find out how to put right.
If you have trouble bringing up the diagnostics it is usually caused by not timing the button presses just right, maybe press ok two or three times as soon as the box goes off.
The recording light being on when the box is off is a setting in the menu called RF Bypass. Press menu button twice to bring up the full screen menu, arrow down to setup press ok, arrow down to cable box setup press ok, arrow down to RF bypass (if it is on, turn it off by pressing the right arrow), then press exit to get out of the menu.
Feb 02, 2010 | Televison & Video
How do i get icons offmy main screen on lg viewty?
If you mean the group of 9 icons grouped together on the opening screen, just "swipe" the touchscreen beneath the icon box ( in either direction) and it should change back to the normal opening screen. This is reversable if desired. Hope this helps.
Jan 07, 2010 | LG KU990 Viewty
They have changed the keyroll method and auto update will not work for now so you have to manually input keys everytime they change:
1. Press Menu, press OK on language settings.
2. Press 1968 TWICE on your remote.
3. Key screen will open, use the < or > button on remote to get to Nagravision screen if it is not visible.
4. Press OK on N**. Go down to key data field and enter codes for line 00 first. Use < or > arrows on remote to change numbers/letters.
5. When done press blue button to save and exit.
6. Now scroll down to second N** line and press OK.
7. Do same as above and change key data field for line 01.
8. Press blue button to save and exit.
9. Exit out all the way to view channels.
Sep 17, 2009 | StarView SV211K 2-port KVM...
Televison & Video Logo
Top Televison & Video Experts
