Question about Waring Blenders
I cant figure out how to get the blender coupler out of the blender for a Waring MX1000XTX. The coupler free spins in both directions so I can't see how a rench will help
  • 3 Answers
SOURCE: Waring blender BB180
try to soak hot water around the base unplug firts and pour hot water slowly at the base
Posted on Jan 01, 2008
SOURCE: Waring blender - new blade
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Posted on May 24, 2008
SOURCE: Replace clutch assembly Waring BB150 Blender
Remove the little rubber feed on the bottom of the base (they might be glued a bit so be careful not to rip them). This will reveal 4 phillips head screws...remove them...this will open the base and reveal the back site of the rotor. In the middle you will see a turban blade like wheel with a large flat tip screw. Wedge a large screwdriver between the teeth of the old clutch so that when you turn the flat tip screw it will stop rotating the other end. Turn the screw with some force to the right to losen the clutch...then do the reverse to get the new one on tight...put everything back together and there you have it.
Keep in mind that this might void your warrenty if you still have some on it.
Posted on Nov 15, 2008
  • 5 Answers
You can call Waring and they can send you a parts breakdown showing the order the parts need to be in. If you still have problems they can go over the assembly with you on the phone or direct you to a service center near you to help.
Posted on Mar 09, 2009
SOURCE: How do you get the blender coupling driver off the
how do you change the coupler on a waring extreme blender
Posted on Apr 08, 2011
Why can't coupler turn blade?
Drive shaft may be stripped
Dec 27, 2015 | Waring RB70 Blender
I have a waring pro blender Model WF2111211 It's glass he blade part doesnt come off. motor runs fine but blade really tight won't spin so the motor smells burn out trying to get it to free.
Heat up a cup of water in microwave until boiling in a two cup Pyrex measuring cup. Add one more cup of tap water. Our it in the blender and let it soak. If it doesn't work, repeat but with less tap water.
Sep 15, 2015 | Waring Blenders
Replacing drive side coupler on a Waring HPB300 blender. Threads don't match???
There are not normally any tricks, sometimes they are left hand thread though. More likely if the thread size is really too small then wrong part has been supplied.
Jul 10, 2015 | Waring Megamix Commercial Blender Hpb300
The gear at the base of my waring bb 180s blender is stripped
You can try the sears online parts store for help they may be able to get the parts you need as they are pretty much the same. iF YOUdon't find it let me know and I will resurch it for you and find the part it is eather the druve nut has come loose or the teeth on the plastic shaft has worn off, it is possible to super glue it to hold if you cant find the part.
Nov 12, 2009 | Waring BB180 Work Top Blender
Waring blender - model 51bl25
My Waring 51BL16 is having difficulty blending and some mechanism on the inside keeps spinning once the blender has been turned off...any ideas?
Mar 15, 2009 | Waring PBB 201 / 204 / 209 / 212...
Feb 21, 2009 | Blenders
Feb 23, 2008 | Blenders
Blenders Logo
148 people viewed this question
Top Waring Blenders Experts
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
