Question about Kenmore Washing Machines
Kenmore 110.28082700 long fill
I have a Kenmore 110.28082700 washer (Oasis HE) I get the LF (long fill) error a lot. On the larger load settings like towels/sheets, it fills from the fresh fill for a couple seconds, rotates the basket for a while, then fills from the fresh fill for a minute or so. Then, it switches to filling from the detergent cup, and fills the rest of the way from there. This can take 45 minutes! The fresh fill (sprays from the rear of the basket) flows quite fast, maybe 2 gallons/minute, but the detergent cup flows VERY slowly, maybe 3-5 minutes/gallon. I have several water valve assemblies here, they all do the same. The hoses are fine, as can be seen from the fresh fill rate. I'm pretty sure the detergent cup is not blocked, I took it off and ran a sink faucet through the tube. I have checked that the basket clutch is free to move, and did the pressure transducer calibration step with the manual diagnostics. I have a Whirlpool repair manual a service guy gave me, but it doesn't quite match this model. The auto diagnostics show codes F30 and F51, but these may be quite old. I did have a motor burn up on me a couple years ago, those codes might refer to that. Anyway, the manual I have does not list an F30 at all, and the motor is working fine. Does anybody have any ideas about what is causing it to fill forever through the detergent cup? Seems like it should maybe just do this at the end of the fill, for a few minutes or so, not fill the whole machine through that cup. Thanks, Jon
SOURCE: Washer takes forever to fill
You said you checked the screen at the faucet end, did you check the one at the washer connection? Most washing machines have a wire mesh screen which sits inside the plastic connector that the hose connects to. You will have to use a small pointed object (like an ice pick) to remove the screen and clean it. Be careful not to damage it, I have ruined them on more than one occasion and had to replace it with a new one. If that is not the problem, there is likely a problem with the valve that is controlled by the hot/cold knob. I am not familiar with your washer brand, but mine required quite a bit of disassembly to get to the valve and switch, and in my opinion is a job better left to the local repair man.
Posted on Jun 04, 2007
Healeyman
  • 1198 Answers
SOURCE: Whirlpool model LSR7233EZO / doesn't fill fully
The fill switch is a very sensitive device. You can test it by blowing into the tube, listen for the switch to click, or use an ohms tester. They are actually adjustble, the adjuster screw usually has glyptol (thread lock) on it. I would replace one before trusting an adjusted one.
Posted on Jul 29, 2008
RescueTech
  • 145 Answers
SOURCE: kenmore series 70 top load washer - cold water fill very slowly.
The screens in the line are clogged. There is usually a screen in the washer hose at the point where it is connected to the faucet as well as one by the water inlet valve. NEVER REMOVE THE SCREEN BY THE WATER VALVE. As for the one in the cold water fill hose, that can be cleaned or replaced.
Posted on Dec 14, 2008
rpbuice
  • 161 Answers
SOURCE: Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Posted on Jan 08, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite oasis washer has error code f1
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 16, 2010
What is the LF code on my kenmore elite oasis
The LF code stands for long fill.. I would suspect a water inlet solenoid valve as the most likely suspect. It may be the hot or the cold valve. If the valve does not completely open the time to fill your machine takes too long. You can't replace just the one valve because the part contains all of the water inlet valves. That of course jacks up the cost but what can you do.
Jun 29, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Itshows LF what do i do?
LF code means long fill on the water supply,if it takes too long to fill it will shut down,remove the water fill hoses and check for screens in the hoses and washer water connections and see if they are plugged with sediment
Aug 30, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis top loader giving us continual LF error code... how to fix?
long fill error code. might wanna clean ur screens. take the hoses off ur washer and clean the screens
Jan 31, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Keep getting an LF error
Hi There
I have found something for to read and this should help you. Try this and let me know how it goes.
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya. Merry X-Mass and a Happy New Year.
Best Regards Richard
Dec 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
The dreaded LF code
HI, there is not a defect notice or recall on this particular unit but, we get a lot of complaints about this specific issue concerning the LF code on a frequent basis. this issue dose concern the inlet valve.
The replacement will work better than the factory installed piece. This is basically a blind defect.(defective factory part).
Jun 19, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Washer Oasis displays letters LF and is unable to complete washing cycle. Also, could you please send a manual via e-mail?
You can find owner's manual for Kenmore Oasis washer at http://www.managemyhome.com by searching for your model number. From the Kenmore owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
"Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it."
Apr 30, 2009 | Washing Machines
Kenmore Elite model #110 27082601
In reference to the LF error code on your Kenmore Washer
When your washer displays error LF , it is due to low water pressure, slow or continuous fill.All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems;
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine isn't supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house
* Error Codes- LF for long fill or FH for no water detected.
o A plumber may need to be consulted if the pressure is found to be too low.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27092
LF means long fill or that is what the repair tech told me when I first got my set and was having major issues with it. What he said was causing it during initial fill up the drain hose if inserted into the drain to far will create a siphon. It is a simple fix just barely put your drain tube into the wall and you should be set.
Jun 01, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 2708..LF error code
LF = Long Fill
If the water is on and screens are clean there is a test you can do to check the log valve. There should be a repair manual inside the front panel of the machine. If yo use a screw driver in the front to open the top you should find it on the inside of the front panel. Good Luck
Dec 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
60 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
