Question about Panasonic KX-TGA470S Cordless Phones
I have Panasonic model KX-TGA470. One of the four phones continually says busy, charge for 7 hours which I've done, then says use rechargeable batteries.
I have replaced all phones with regular new batteries and no problems with them.
  • 4 Answers
SOURCE: Panasonic Phone KX-TG2432
I have the same probloem with a KX-TG 5672. I am going to call 1 800 2111 7262 on Monday and ask for technical support. If you get a solution, pls notify me.
Posted on Jan 26, 2008
SOURCE: I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Posted on Aug 11, 2008
  • 2460 Answers
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Posted on Oct 01, 2008
SOURCE: Panasonic base unit went dead
Posted on Mar 23, 2009
SOURCE: battery fully charged but phone dies within a minute
A friend that worked for GTE advised me some yrs ago to do this and I have NOT had a problem with another battery since
when you get any new Battery charge it plugged in to the ac AND phone jack for a minimum of 24 hrs without using it.
all batteries have some memory and deminish power over time but if it was NOT fully charged to begin with as a yr goes by so does the battery life. hope this works,
Posted on Apr 16, 2009
Is there a factory reset method for the Panasonic KX-TGA470? The standard time adjustment methods are not working. The clock is perpetually one hour behind.
Reset Panasonic Phones to Factory Default
Step 1: Enable Embedded Web
Step 2: Determine IP Address of Phone/Basestation
Jun 08, 2017 | Lands Phones
How do I remove the list of blocked calls on Panasonic KX-TGA470
Note: the handset is model KX-TGA470. The phone base system model may be KX-TG7731 or another KXTG7741. Other model numbers also use this handset.
You have to remove the entries in this list individually. Press Menu followed by the following # 2 1 7 . Select a number in the Blocked call list (with the up/down arrows) and select Erase. Use the up/down arrows to highlight Yes and then press Select. Alternatively, you can use navigate the menu system and look for Initial Setting and then Call Block. Press Select to enter the sub-menus. See page 41 of the manual for the section on Editing the Call Block list. See page 37 to see the menu tree for the Initial Settings sub-menu. The manual is available here: .
I hope this helps.
Mar 23, 2017 | Panasonic Lands Phones
How can i put my phones KX TGA641C in French?
PDF]Operating Instructions - Panasonic Canada
Panasonicappropriate service offered by your service provider/telephone company. .... Feature.KX-TGA641C. KX-TGA740C. KX-TGA840C. Handset. Display colour/ size ..... "Fran?ais" as the display language. .... This feature allows you to put an outside.
[PDF]Installation Manual - FTP Directory Listing - Panasonic
PanasonicNov 19, 2008 - Charge the batteries for about 7 hours before initial use. Additional Digital Cordless Handset. Model No. KX-TGA641. Installation Manual.Missing: french
Dec 17, 2015 | Lands Phones
Panasonic phone no dial tone. Picture of telephone pole on screen. What's going on?
Have you confirmed that you have a good connection at the base unit by plugging in a regular corded phone?
Dec 01, 2014 | Panasonic KXTGA470S KX-TGA470S KX TGA470S...
How to setup voice mail for panasonic phone kx-tga470?
The KX-TGA470 is an accessory handset. It uses whatever answering machine or voicemail system you have on your telephone line. Please refer to the documentation for that answering machine or voicemail system.
If you require further assistance, please add a comment to your question and specify the answering machine or voicemail system.
Aug 23, 2014 | Lands Phones
Panasonic cordless phone KXTG2431 discharge too fast
Hi,i'm hamed from IRAN
I have a panasonic phone model:KX-TC1282JXB and it has a problem: Discharge very soon the battery and recharge hardly or phone can't recharge it !?
<< My dicovery solution worcking 100% >>
1-remove battery from remote-handel.
2-create two wires.
3-the jumper of battery must have two wires(red & black).
4-contact you're created wires to jumper of battery.
5-be careful! now you must connect two wires to base of phone where the remote-handel settle there at below be exist two slots "phase+" and "null-".
note: when you connect correct,the green lamp must be shining.
Recommend: (near slot by base keyboard connect black wire) and (other slot connect red wire).
6-connected battery must be take between 45min - 75min.
note: the battery to be warm don't worry, just control to pass time.
7-then release base and battery form two wires.
8-connect the battery to remote-handel,you can see it has charged for minimum amount (one-unit)
9-finally connect remote-handel to the base for give full charge,it take between 8h - 12h.
you can ask me you're question(s) :
bye :-)
Jan 24, 2009 | Panasonic KX-TG2431 Cordless Phone
Panasonic KX-TGA470S Cordless Phones Logo
37 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
