Question about Kenmore Sewing Machines
Can't find zigzag cam assembly for kenmore sewing machine 158.1400
    Master:
  • 918 Answers
Try ebay.com
Posted on Apr 02, 2017
5 Suggested Answers
vash4me
  • 5 Answers
SOURCE: Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
Posted on Jan 13, 2009
  • 980 Answers
SOURCE: Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Posted on Nov 06, 2009
  • 980 Answers
SOURCE: my older 80's kenmore sewing machine won't
Either it is a blunt or bent needle, or the needle is in the wrong way round or most likely the machine will need retiming
Posted on Mar 03, 2010
murf427
  • 336 Answers
SOURCE: Threading Singer Zigzag childs sewing machine
If you go to support on the Singer website, you can download an owners manual, showing you how to thread the unit.
murf427
Posted on Aug 01, 2012
How do I fix the zigzag on the bernina 930
1. The switching pawl (lever on the top cover that switches from zigzag to cam patterns) may be engaged in the cam or automatic pattern side. Check that first.
For zigzag application, the lever must be engaged in the zigzag side (lever pulled back toward the operator). The stitch width dial is then used to provide your choice of width.
2. It is common, due to oil varnishes, that the switching pawl that is actuated by this lever is stuck between the zigzag and the automatic position, thus preventing the transmission of power to either the zigzag cam or the automatic pattern cams and to the needle.
The best way to detect this is to remove the top cover. You can then switch the lever back and forth to observe if the switching pawl engages firmly into either of the receiving forks. If the switching pawl is sticking, a few drops of certain solvents are applied by a technician on the switching pawl support. The switch lever can be rapidly switched back and forth until you see the switching pawl engage into the receiving forks and you hear a crisp clicking during each engagement. This repair can be permanent or it may create only a temporary fix due to the amount of oil varnishes on the parts.
If the machine is heavily varnished, it suggested that the parts be disassembled and cleaned for flawless performance. If the machine had been sprayed with WD-40, petroleum based solvents like mineral spirits will not break down these varnishes.
A caution regarding solvents...DO NOT USE (WD-40) as your solvent. WD-40 is a marvelous product for its intended application as a water displacement device. It is not to be used for lubricating a sewing machine. Note: "Bernina Technical Information bulletin #1" issued in 1982, forbade the use of such spray lubricants and solvents. SewTechnical Home
Oct 06, 2014 | Bernina Sewing Machines
My Bernina 830 sewing machine will not do a zigzag stich
We are assuming that the zigzag width dial is at the widest position but the needle will not move laterally for zigzag... The following logic should be applied for Bernina machines 530, 730, 830, 930 machines with a guided motion zigzag cam.
Sep 28, 2014 | Bernina Sewing Machines
Singer sewing machine needle moving to the side after it's in the fabric for a zigzag stitch
If you can grab the hand wheel and move it right and left, then it probably needs a plastic collar that goes next to the left upper shaft bushing.
If not then the cam timing needs to be adjusted.
Mar 13, 2014 | Kenmore 15516 Mechanical Sewing Machine
Zigzag feature is not working
Remove thread from machine and open door to where you put cams in. Step on pedal and run at full speed. It the mechanism where the cams go spinning? It is likely that your elna graph gear is broke
Jan 09, 2014 | Elna Sewing Machines
Singer Touch and Sew Model 648 will not zigzag
There is an arm in the head that does the zig zag movement and attaches to the needle bar with a pin. If that isn't connected zig zag won't work at all.
Jan 19, 2013 | Sewing Machines
Sews straight when on zigzag
it's possible the zig zag gear or cam could be worn or damaged
and the machine should be checked to see for sure what's happened.
Nov 29, 2012 | Sewing Machines
How does one get the kenmore 12102 to sew in zigzag stitches?
The dial at the top right hand of machine ,turn it fron 0 to 1-5 for zigzag
May 20, 2010 | Kenmore 12102
My kenmore 1760 sewing machine won't perform the zig zag stitch
to perform the zigzag on your machine. adjust the wheel on the zigzag sign.
Mar 11, 2010 | Brother 1034D Mechanical Sewing Machine
Nov 05, 2009 | Kenmore Sewing Machines
I forgot how to set the machine to zigzag, Does
There is a Yahoo group for owners of Kenmore machines. They might be able to help you. http://groups.yahoo.com/group/vintagekenmoressew/
Also, I just found an instruction manual available for a good price on Amazon also: http://www.amazon.com/Instruction-Manual-Kenmore-Zigzag-Machine/dp/B001PVAR5Q
Oct 20, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
