Question about Hoover Washing Machines
Hoover washing machine shoots water back in draw after cycle ends?
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
Jimster
  • 240 Answers
SOURCE: Hoover 600M washing machine cycle issue
Sounds like you may have a timer problem. You might be able to pick one up at a appliance parts center. Most of the time, they can be pretty pricey item, if you can even get one for older models. Check EBAY as well, sometimes you can find hard to find parts for pretty cheap. Replacing the timer shouldnt be that hard. UNPLUG the unit, remove the console, which should be held on by screws, the remove and replace one wire at a time back to the timer. Use caution when removing the timer knob, you dont want to crack it. Most knobs remove by unscrewing to the left.
Posted on Sep 05, 2007
  • 1314 Answers
SOURCE: HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Posted on Mar 23, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
  • 77 Answers
SOURCE: washing machine
-the conditioner compartment may be blocked
- the cable with spring that change course of the water may be out,
Posted on May 08, 2009
When washing machine does not take fabric softener in still left in draw at end of wash
Hi,if you start the cycle again open draw despencer you should hear and see water wooshing inside if nothing then the valve that lets the water through must have packed up or despencer is blocked if you can hear the water clean despencer draw.
hope this was some help
Mar 28, 2015 | Washing Machines
Hi I have a LG front loader washing machine after the was cycle is finished there is still washing powder on the draw and it's gone hard have clean the draw and filters
problem with the water pressor. its should be 5 bar.if its not some remaining detergent you can find end of the cycle.
Dec 15, 2013 | Washing Machines
HOOVER HNF 7147. BLOWS THE HOUSE RCD ONLY WHEN ON A WASH CYCLE AND NO WATER BEING FED INTO DRUM. I SUSPECT THE HEATING ELEMENT IS DRAWING TOO MUCH DUE TO NO WATER IN THE DRUM. BOTH INLET VALVES ARE OK AS I...
You need to check the circuit in the wash cycle. Disconnect the power to the heater coils and see if the fuse trips. Also the voltage at inlet solenoid must be checked when the program cycle is on the wash , is not the program controller board is fault, possible a wrong output from the processor.
You can isolate the circuits, the heater, the motor drive to see if the trip stays. Also check the inlet and the drain pump on a test bench to confirm the working of the valve which will infer the case.
Sep 16, 2011 | Hoover Washing Machines
I have a Bosch front load washing machine bought approx. 2006 model no. WF02467GB/01. The problem is that the pre wash draw section is taking in water towards the end of the wash cycle and the fabric...
I have a Bosch front load washing machine bought approx. 2006 model no. WF02467GB/01. The problem is that the pre wash draw section is taking in water towards the end of the wash cycle and the fabric conditioner section is remaining full of water
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 28, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Apr 13, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Washing machine
Hoover washing machine This video will show you how to keep your soap draw clear and how to service the parts
Feb 19, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Our hoover ultra care 1300 large load washing machine spin fault
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Hoover H120M Washing Machine No fabric softner and dial clicking round
always check your carbon brushes which are situated at your motor covered in a plastic covering must be at least 8ml long these start at 1inch in length may not be giving enough contact to your motor for the timer to click into action m8 but if these are ok then it will be more than likely your timer which is faulty with it not doing the water inlet valves properly
Nov 03, 2006 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
