Question about Miscellaneous
I have a top power roll 2 and it just stopped working...what can I do?
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Check the plug.
Posted on Feb 03, 2017
My philips ambilight wont switch on i can hear clicking noise and red standby light keeps flashing any ideas
U have tools like a soldering iron,desoldering pump or roll of desoldering braids,a roll of solders and understanding basic electronic also can do basic soldering?This problems,most of the times are causes by those dying soon to be dead components call capacitors on the power supply board.Yes,take ur tv aparts,the power supply board,that the board,where the power a/c cord plug into it.Check the power supply board for those dying soon to be dead capacitors parts,it alway bulges up on it tops or puffing up on it tops.Replaced these dying soon to be dead capacitors parts,will solved ur tv noises clickings,power LED light indicator will stop flashing.Tv will power up normal again an work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 20, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
What is a ''Roll Stop''?
The only "motor mount" that goes bad is really called the roll stop. It is located on the support bar, under the car in the middle of the engine/transmission. The roll stop is on the front, top side of the support.
You can remove it without the need to jack anything up, it does not hold any weight, it keeps the motor and transmission from flexing too much when you accelerate or engine brake. With a bad roll stop there will be more pressure on the exhaust system and a broken flex pipe on the front of the exhaust system will be the result. The flex pipes can cost up to $600 on some vehicles so replacing the roll stop is a good idea if you have too much motor twist or a knock under the vehicle from the exhaust hitting the floor when accelerating.
Good luck.
Dec 09, 2009 | 1997 Mitsubishi Eclipse
1990 Honda Accord rear door window, wont go up last 2 inches
the motor is attached to a regulator.The regulator is basically a pulley with cable control.Have a look and see if the cable is binding or jump off the roller
Sep 16, 2009 | 1990 Honda Accord
Power windows on front passanger side not working.
replace the window motor if u believe the switches are good.
Aug 07, 2009 | 1999 Cadillac DeVille
I own a 1995 mercedes SL500 and recently started having trouble with the left front door window. While stopped in a construction zone, I rolled both windows down. After leaving the construction area, I...
The window position is monitered by the softop control module. It sounds like the glass is very dirty and drawing too much amperage during window operation. The soft top is electro hydraulic. The roll bar is operated normally with hydraulics but it is mechanically released in an emergency situation. 1st make sure your windows are clean and the express(one touch operation) is working-the soft top will not function properly if the windows are not synchronized. Next be sure your roll bar works-hold swith in up position to lock roll bar rams in if they have been deployed. next put your top all the way up. untill windows roll up and try it with the engine running and trans in nuetral- if it still does not work mechanically secre rear of top with tool provided in your tool kit the owner's manual will tell you how to do this. good luck
Jun 19, 2009 | 1995 Mercedes-Benz SL-Class
My Power Windows don't work!!
it is flashing you the code either six or sixty six any parts person can tell you what this code means it is more than likley a solinoid or relay switch
Jun 08, 2009 | 1999 Ford Explorer
Screen won't stop rolling out
There is a rubber grommet on the left top of the projection screen, insert the supplied Allen key and turn anticlockwise and adjust turn by turn till the screen rolls out with just 2 to 3" of the black border shows on the top
May 16, 2009 | Draper Baronet 106 in. diag HDTV MW...
Mitsubishi mod. vs-5072 rolls how fix?
check for swollen capacitors- bad capacitors will cause the screen to roll. If the top of a capacitor even looks SLIGHTLY puffed up, replace it!
Dec 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Attempting to locate parts for a 1989 Corniche, 2 rear window motors, 2 power seat motors, gas guage and sending unit, and a convertible top. Any assistance would be appreciated
Hi I am Vortash here in the Uk we have quite a few Rolls Royce Breakers here is a site you may find that can help you and if not will know somone who can .. http://www.breakeryard.com/cars/gearbox/ROLLS-ROYCE.aspx
Regards Vortash
Jul 29, 2008 | 2007 Rolls Royce Rolls Royce Corniche
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Miscellaneous Logo
24 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
