Question about Water Heaters
Model mr75245 leaking water from top. Before it started leaking we ran out of hot water a couple of times.
davidkay61
  • 23 Answers
SOURCE: running hot
Radiator Fan Control Relay Switch. I bet your electric fan doesn't run?
Posted on Dec 01, 2008
  • 699 Answers
SOURCE: My car ran hot and then I filled with water, now
Running out of water or oil will cause your car to overheat to the point where you now probably have either/both a blown head gasket or a crack cylinder head: to check, when your car is cold, remove your car radiator filler cap, look inside the hole to see if you water is milky (this would be oil leaking into the water) or if after you restart the engine, the water bubbles badly (this would be crack letting air into the radiator). As a short term solution, you can try to use a heavy duty radiator anti leak additive but remeber that this is not a permanent solution and may not even work if the problem is severe enough. Hope it helps.
Posted on Dec 22, 2009
SOURCE: My Rheem electric hot water heater occasionally
It sounds like TP valve is releasing water, but you don't describe where water is located.
Run through process-of-elimination check list on following link:
http://waterheatertimer.org/Leaking-water-heater.html
1) If problem is TP valve, event could be caused by 'stacking'
Stacking is where you draw amounts of hot water many times in succession.
Top part of heater is plenty hot because water heater is keeping up with hot water draw.
Incoming cold water enters bottom of tank through dip tube causing thermostat to read cool temperature and activate burner or element. This causes higher than ordinary temperatures at upper part of tank and TP valve reacts by releasing water.
2) TP valve could be going bad.
http://waterheatertimer.org/How-to-replace-TP-valve.html
3) Improper venting can cause gas water heater to have water on top of tank or dripping down inside tank where it shows on floor after rusting out combustion chamber.
4) Thermostats are old or not reading correct temperature.
Turn down thermostats:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Replace gas valve on gas water heater, and flush tank.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Replace electric water heater thermostats
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 17, 2011
  • 9 Answers
SOURCE: Takes a long time for water to get hot in all
bobo mayuk
Posted on Feb 23, 2011
  • 5089 Answers
SOURCE: water heater leaks
You have to replace water heater.
But you can buy-time if leak is small by turning heater off except when you need hot water. This will give you 30-60 days to shop and find best heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
To prevent tank from rusting in this manner, inspect and replace anode rod each 2-4 years, and keep water pressure below 80psi.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Posted on Aug 25, 2012
Vaillant boiler leaking only when heating switched off.
It would seem a joint has come a bit loose from the heating and cooling cycle. put a drip pan under the leaking area( the drips would evaporate quickly), then next time you shut it down go through all the joints in the area with wrenches to find the loose joint.
Oct 27, 2014 | Water Heaters
Water heater leaks
Aug 24, 2012 | Water Heaters
Hi, I have a Atwood 91043 (Model 37C14U-5). The pilot and main burner seem to work fine (main burner ran a couple minutes then shut down) but I'm not getting hot water at the facet. I have the...
Have you checked back of water heater for proper valve positioning? (by-pass may be on)
Cold water enters through bottom fitting and hot comes out the top. Any valves in between should be closed and any valves going in bottom and out top should be open.
Jun 03, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
My Rheem electric hot water heater occasionally leaks water then stops completely. This has done this three times now over the pact couple years.
Jan 17, 2011 | Rheem Water Heaters
I have a hot water heater that when running seems to build up an excessive amt of pressure. We just replaced the pressure valve because the old one started leaking when the hot water was running for any...
The most likely problem is that the thermostats are set too high. Remove the thermostat cover plates and look to see where the thermostats are set. The range should be between 120F and 135F. Liquids expand with heat so the higher the temp, the high the pressure. Decrease the setting on the thermostat until the leak stops.
The other likely cause is a head of air trapped in the top of the tank. After drawing hot water, it wiill be displaced by the incoming cold makeup water. This will compress any air in the top of the tank. As the water heats, the air will heat and pressure will build - possibly causing the leak. You can purge the tank of air by opening the pressure relief valve until water comes out (which I assume that you have already tried).
Dec 09, 2010 | Whirlpool Water Heaters
Water is putting the burner out
if you check the bottom of the tank or there is water on the floor constantly..check the top of the tank most of the time the shut off valve is leaking or the hot cold connection on the top is leaking..if both these are dry then there could a crack in the tank
Jul 05, 2010 | Rheem Water Heaters
White sediment in the hot water
replace heater-have u ever drained heater?turn off water supply-drain heater .try this a couple times.if u replace heater put water filter on incoming water.
Jan 07, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
42 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
