How to hook up surround bar to my flat screen?
4 Suggested Answers
  • 231 Answers
SOURCE: hooking up game system to flat screen tv
you should have several kinds of inputs options on TV .If you have a surround audio receiver .Simply go direct to receiver on any available input .If using diect to TV , use any available input on TV .More likely VIDEO 1 or 2 (game or camera input)on front or side of flat panel
Posted on Nov 29, 2007
  • 1779 Answers
SOURCE: INSTRUCTIONS ON HOW TO hook
Use the Audio Output jacks Red/White from the Tv to the Tv Audio In on the Yamaha. If the audio out is being used from the tv now then go to Best Buy, Radio Shack and get a Y-adapter (rca jack type) with Single Male--Double Female. That will split off the audio coming out of the tv.
Posted on Dec 06, 2010
taseana_howa
SOURCE: hooking up a sound bar to a 42'' flat screen
Hello I have a model hw-j470 and only the sound bar coming on and none of the other speakers
Posted on Aug 03, 2015
Can i hook pioneer speakers from a system to my lg flat screen
Absolutely! To provide a better solution to your problem, however, you will need to provide model numbers of your TV and surround sound system. Depending on the available hookups and your hardware, you may need a received to make everything compatible.
Feb 13, 2013 | Proscan 32LA30Q Television
I have not watched my Sharp Aquos TV in a few months, and I just turned it on and am getting these lines across the screen. Any ideas on why?
It could be a faulty or crossed wire cable have you hooked up another flat screen to see if the same thing appears and remembervto leave all settings the same on your surround sound or tuner. if it stays the same on another flat screen then you know its the wiring in your home going to the tv or you dont have the wires from you tv to you tuner from your surround sound hooked up properly. i hope that you get it figured out and fixed. make sure you triy what i had mentioned. good luck
Dec 22, 2012 | Televison & Video
What kind of audio system do I need to purchase for this set. The speakers are just terrible.
I changed my audio equalizer setting to "POP" and I got much more pronounced separation. Also, make sure the SURROUND is set to "ON" in your settings or simply hit the SURROUND button on the remote that came with the TV.
The "AUDIO OUT" jacks on this set apparently only work when the input is set to "TV". I wanted to hook a couple of external speakers up as well and found they would not work when hooked up to HDMI to a cable box. I mean how many people by a large flat screen like this if they don't want to view HD? Like about zero! The AUDIO OUT works only when TV is selected for INPUT
A work around is to use the headphone jack and hook a couple of external speakers up to that.
If you want to go for a higher end home theater sound bar system so that you can route both DVD and CABLE box through it via multiple HDMI's you can choose from SONY, Phillips etc.
I wrote to Sharp about the AUDIO OUT issue. It's rediculous that they only work when TV is selected for input. But you might try using the heaphone jack alternative if you find a set of speakers that sound good to you. Hope this helps.
Dec 24, 2010 | Sharp LC42SB48UT 42 in. LCD TV
I want to hook -up my audio from from my flat screen thur my samsung surrond sound!
Use an HDMI cable from your surround sounds output to your t.v.s input or use a three wire red,white,andyellow r.c.a. cable from surround out to t.v. in.
Sep 18, 2009 | Samsung 500w Rrss Rear Reflecting Surround...
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
Hooking my flat screen tv to my home theater
Since your output is coaxial (rca) you should be able to find an input for coaxial that will work on your surround the setting on your surround will be either coaxial or digital input,
hope this helps
it would help if you said what kind and model of surround you have
Dec 02, 2008 | Philips Magnavox 42MF521D/37 Television
Surround sound
Make sure the RCA cable is going from an audio OUT on TV or DirecTV box to a red/white (non-digital) audio IN on surround sound or home theater system.
Dec 29, 2007 | Insignia NS- 27" TV27 TV
DTS compatibility
no problem., Your flat screen has two audio outputs, one red and the other white. Connect these two into your surround system and the system will handle the rest.
Dec 28, 2007 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Hooking up game system to flat screen tv
Nov 29, 2007 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
