Question about Marshall Music
Manual for ARYZTA OS1
Need a manual to present to the fire marshall to confirm it doesn't need a hood.
The fire marshal will not investigate
statements are not questions and you will not get answers to statements
Jan 10, 2017 | The Music
Need repair manual for g15rcd marshal amp
found one here :-
http://www.eserviceinfo.com/download_start.php?downloadurlid=48727
Apr 14, 2013 | Marshall Amplification Music
Doesn't work !!
That footswitch is the right one for the HAZ40 but, it is programmable. I recommend downloading the manual and follow the instructions for programming and make sure you are using it properly.
Mar 05, 2013 | Marshall Amplification Marshall PEDL10049...
Marshall mg 100hfx preamp board not working
You need to signal test this board to confirm if the analogue preamp IC or any logic gate has failed.
Otherwise the only option is to replace the board. check using a signal tester and signal analyser or if one channel is working it can be compared. Other wise it is best to take opinion and support
Jul 05, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall AVT 100 dfx doesn;t work
junn561,
Thank you for asking me directly to help you with your problem. However, either the question you are asking is not within my area of expertise (I am an automotive repair technician), or the question is incomplete and does not contain enough information for me to help you.
Dec 11, 2011 | Music
I bought a Marshall as50d 2 months ago, it sounds great but my problem is that it shuts down after 10-15 minuets! Total disconnection as if u pulled the AC plug!! The red light on the power button turns...
This can be due to either a RUNAWAY of some power circuit or there is a dry point of soldering which seems to get aggravated when the board is working or heating.
So when the fault occurs check the power to the amplifier, the output stages. If a tap bring about life then the case of the dry soldering is justified.
If not this can be due to power failure due to semiconductor failure. A tracing with voltage/current/signal will be needed to confirm . USe a multimeter to check the voltage line , check the secondary to the circuits, specially the outputs.
Sep 02, 2011 | Marshall Amplification *new* Marshall...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Music Logo
15 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
