Question about Kitchen Appliances - Others
The blades are loose and come off when in dough cycle.
Why does water leak out when filled passed the top of blade
About 11,000 results (0.81 seconds) Search Results
    [PDF]Instruction Booklet Premier™ 11-Cup Series - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-2011.pdf
    Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
    [PDF]Download Manual - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
    Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
    [PDF]Food Processor - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
    Cuisinart
Feb 08, 2016 | Cuisinart Prep 11 Plus Dlc2011chb Food...
I was given a regal bread maker model k6751 is the kneading blade supposed to turn the whole time?
No, the blade only turns when the machine is in a mix or knead cycle. There are many minutes where the blade does nothing. This is when your machine is allowing the dough to rise or at the end during the bake phase.
Nov 07, 2013 | Kitchen Appliances - Others
I have had a Panasonic breadmaker from Jan 2009 and it has been in regular use without problems. Recently on several occasions (not consecutive) the dough paddle has become detached during the mixing...
The kneading blade on the Panasonic bread makers is designed to fit loosely. If the dough is 'stiff' the kneading blade may stay in the bread when the loaf is removed from the pan. Allow the bread to cool completely before removing the blade carefully. Some types of flour absorb more water than others, so you can try adding an extra 10 - 20ml of water next time to see if this results in a slightly less 'stiff' dough.
This problem can also be caused if crust has built up underneath the blade. Make sure to wash the blade and its spindle after each use.
Trust this is helpful. Thank you for using FixYa!
Oct 19, 2011 | Panasonic Kitchen Appliances - Others
How is it possible to bake a loaf without a blade inside it?
You can't. To do so would interfere with the cycle and spoil the bread. The blade reverses at the end of the mixing cycle for it to drop flat so it does not stick so far into the bread. If it doesn't, try soaking the blade in warm water for a while and work the blade hinge back and fore to clean, Cleaning this hinge properly needs patience. As for the "ugly end" as my kids call it, we give it to the dog if no one wants it. I've had two previously, ans they were the same.
Oct 05, 2009 | Sunbeam Kitchen Appliances - Others
My 12 cup kitchen aid food processor dough blade is seriously stuck inside the bowl after I made some dough. How do I get it out?
Dough is normally water soluble. Try soaking it in water for a several days up to a week. Then try prying it loose.
Sep 17, 2009 | KitchenAid Food Processors
Magimix blade is stuck
You need to replace the spindle i'm afraid which gets worn after a time. There a UK company that sells replacements and tells you how to replace it. Not a big job though a bit tricky. magimixspares.com
Jun 28, 2009 | Magimix 5100 Cuisine Systeme Food...
Motor fails to operate - very hit and miss
Make sure you are using the dough blade for dough instead of the regular blade - dough will cause the regular blade/assembly to gum up. This is actually a VERY high quality unit w/ a 20-year motor warranty. I would see if you get better results with the dough blade. Don't give up on it yet.
Dec 14, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Kneading Blade Stuck on Kenwood Mixer KM300
Lightly tap out the dough with a piece of wood in the direction you would usualy remove it
Jan 16, 2007 | Kenwood KM300 Chef Stand Mixer
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
