Question about Kelvinator Refrigerators
Kelvinator opal n520 energy rating - Kelvinator Refrigerators
2 Suggested Answers
  • 528 Answers
SOURCE: We have a Kelvinator Opal
Hi there!
From what you say it is evident there is a short circuit. Probably the live wire is passing electricity to the body of your Kelvinator. For your protection, the main circuit board trips off. (Otherwise you will get an electrc shock).
Now you have to find out where the short is.
Unplug it first.
Open the plug (if it can be opened) and check for damages or whether live and earth wires are touching.
If there is no problem with the plug, check along the wire for cuts or damages. Specially check where it touches the body of the refrigerator.
If the short-circuit occurs at an internal component like the compressor, there is little you can do.
You may be able to use the fridge by removing the earth wire from the plug, but this will be life-threatening. I strongly advise you not to do that.
Posted on Sep 04, 2011
Kelvinator opal upright freezer is over there a temperature control somewhere or what could be the problem?
the problem could be the heater element, bimetal, thermostat, fuse.must open freezer cover and check.
Nov 14, 2016 | Kelvinator Freezers
Kelvinator opal after shifting,it only starts for a minute and stops will not keep going
did you turn it on its side if you did stand it up for 24 hours unplugged from the power then plug it in and see what happens
Nov 19, 2014 | Kelvinator Refrigerators
N520 fridge is leaking water onto the floor
Clean the drain situated at back (inside) of fridge cabinet (not the freezer). Use a piece of expanding wire about 1 meter long to get around the 90degree bend and into the water tray sitting on top of
This pipe often gets blocked with food particles.
If problem persists it is usually the defrost cycle being too long and in this case the defrost cut-off sensor will need to be replaced .
Feb 19, 2014 | Kelvinator Refrigerators
My kelvinator opal N520 is leaking water at the bottom under vegie trays?
If your refrigertor is an auto defrost model, the drain tube may be clogged.
Dec 19, 2013 | KitchenAid Superba Architect KSCS25INSS...
Kelvinator opal
Replace the defective fan motor
Nov 13, 2017 | Refrigerators
Kelvinator opal
for this you need an expert to put more liquid into your refrigerator to return to normal
Dec 15, 2013 | Refrigerators
We did not receive a manual with our fridge and need to know what temperatures to set it at. It is a two door fridge with a bottom drawer freezer and digital settings. Can you helps? Also do you know how...
If you set both in the middle settings thats generally best. 1 is the on/off and compressor control to run the box temperature, the remaining will say colder /warmer, this can be misleading however as colder actually is colder freezer! not reefer box! so to max that one actually makes the reefer warmer and freezer colder!
Jan 12, 2011 | LG Refrigerators
Fridge running continuously
Another defective thermostat.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2010 | Refrigerators
Hinch for Freezer/Fridge doors is broken,Kelvinator/fridge Freezer Model Opal-N520F-L My address is 30 Murraba Crescent, Tweed Heads 2465, NSW Where can I get the part
Thanks for the reply,
I solved the problem by finding an old warrent card with aphone number which I rang and was tild a nother number and that Electrolux is holding parts for Kelvinator, the nearest Electrolux branch for me was at NERANg a 30 minute drive. Their had the spare part for $20 and I replaced the hinch with a spanner. All is well as good as new.
Amazing how would one know that Elextrolux is holding service parts for Kelvinator, Westinghouse and others, unbelievable really
Ziggy Mireis
Jul 06, 2008 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Kelvinator Refrigerators Experts
Charles T Nevin
Charles T Nevin
Melissa Martin
Melissa Martin
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
