Question about Miele Vacuums
Hello the lower motor on my Miele is not working
My miele flamenco II vacuum cleaner motor makes a loud grinding noise what's wrong with the motor?
Hello Louis Casado,
Most of these motors make noise because the bearings have gone bad and need replacing...
(loss of lubricant or other-than-round ball bearings).
Alternatively... the rotor brushes have picked up something that is clashing with the housing... and needs to be resolved.
Clean it all... really good & run it without a load...
If all else fails to remedy your situation... pull the beater brush and cut everything but the fixed bristle rotor brush... clean it... cut it free... check out all clearances... and return it to service
Hope this helps!
Happy hunting!
Oct 18, 2016 | Miele Vacuums
Miele Solution 5281 motor problem - can it be fixed?
You cant repair the motor but it is not too hard to replace the motor. I have made a video showing how to replace the motor on a miele S5311 which is a very similar machine. The part number for the Miele S5281 motor is 9271290
Jan 21, 2013 | Miele Vacuums
Loud noise ,hot air and poor suction in Miele vacuum cleaner
Hello, this is Ava with Think Crucial.
To make your Miele work properly, a general maintenance will do the trick. Most of the time cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. Please refer to your User's Manual on how you can do this.
You can purchase a wide variety of high quality Miele replacement parts for your Miele Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 11, 2013 | Miele Vacuums
Miele brush bar not spinning
Either the touchpad is defective, or the motor is bad.
May 11, 2012 | Miele Vacuums
Replacement Motor for a Miele S143 Vacuum Cleaner
Your vacuum should still be under warranty. If they dealer does not fix it for free call Miele directly.
Jun 05, 2010 | Miele S143 Bagged Upright Vacuum
Accessing motor Miele Flamenco II
I had the same thing happen to my S251. Open up the vac. There is a third hidden screw in the groove where the accessory door is hinged. It's really well hidden, use a flashlight. Once its open, you'll have access to the power cord and you can test its conductivity. I didn't really believe it could be something as pedestrian as that, but the retractable power cord takes a lot of abuse, and eventually it fails. Replaced mine and the vac works great.
Jul 31, 2008 | Miele S251 Flamenco II Bagged Canister...
Miele S 312i canister vacuum
It could be the switch, reel cord assm., speed control or motor. Most likely not the motor, but possible. It will have to trouble shoot to find out what is bad.
Nov 24, 2007 | Miele S300 Bagged Canister Vacuum
Vacuums Logo
27 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
