Question about Frigidaire Refrigerators
Frididaire fgid2474qf runs for about 2 minuets and throws an i20 code? I understand it's a drainage issue but how can I start rolling out causes?
  • Mike myers Jan 03, 2017
    I'll be home in 30 minuets to pull the dishwasher and check for clogs
    The drain line is clean and clear
    Master:
  • 286 Answers
If possible, try this. Under the unit, most likely toward the back you will find a hose that drains into a small pan. These sometimes get clogged up. Use a thin piece of wire, like a 14 gauge solid or something similar, and push it up into the hose, turning it as you go. You may be able to loosen a clogged line. I hope this helps.
Posted on Jan 03, 2017
Hyundai i20 1600 2009, engine not starting all the time.Battery tested, all good. Roll starts in second. radio windows & lights work.
If it starts by rolling the car then it is a possibility the problem lies in the ignition starter switch, this is the switch that the ignition key turns (unless of course it is push button start). Other possible reasons are a defective fuel pump pressure check valve.
Jul 12, 2016 | Hyundai Cars & Trucks
Frigidare plmb186cc
Good Afternoon Friend,
I understand that you are noticing less noise, after about a second of starting your Frigidaire microwave, model# PLMB186CC. I suggest checking to see if the power level was changed. The blower sound will be different at levels other than "HIGH". As long as it is still heating, there is no cause for alarm. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 24, 2014 | Frigidaire Microwave Ovens
My 95 Jeep Grand Cherokee keeps shutting off while driving. Sometimes I can put it in neutral and restart the engine while rolling. Most times, not. After 5-10 minuets and as many times cranking, it will...
54 - Sync Pick-Up Signal Not Detected (Camshaft Position Sensor/Ignition Pickup). recheck to see if power to sensor. make sure wire is in good shape, to cam sensor. 11 - No Crank Reference Signal At Power control module, crank shaft sensor. check to see if your getting signal from pcm. Good-day!
May 20, 2014 | Cars & Trucks
Suzuki Bandit Dying after running for 15 minuets
Check the breather on your fuel tank.
Jun 16, 2013 | Motorcycles
Usb reading error i20
have issues with my Hyundai i20 where i cannot play songs with my Iphone
Oct 25, 2012 | 2011 Hyundai i20 1.2
Stops running after 2 minuets
Honda engines have an oil sensor that sometimes fails. It will cause this. If the sensor fails it is like not having enough oil and will kill the engine for protection. Just something to look into. Hope this helps
May 01, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
