Question about Cisco Televison & Video
Cisco RL100 ethernet connection comcast tells me it isn't wired up to be used for internet service
CISCO RLA100 is a cable tv box provided by COMCAST
gymowner
  • 679 Answers
SOURCE: connectivity with my comcast cable
I have a comcast for 10 years with a cable modem and tv. The only time I ever had problems and they were major, they needed to run a new line, that's the only thing that stoped the signal from droping.Previous to that, there was an inline amp on the line, and that would have intermittent isues that you describe. Another reason may be the modem, it may be the "old" unit, tell them you need a new modem. They are going to give you a hard time because you aren't using their modem, so every time you call, they are going to ask you to disconnect the router and run through the modem.They can read the modem from their side, and if it is "on", they will stop right there. You are speaking to someone who is out of the country. I made the mistake one day of asking them if there was construction going on in my area, "because they daisy chain" the connection, and if the house next to you has the cable pulled out, it can effect you. The woman told me "she didn't see anything" so I asked her where she was because the homes on both sides werer having work done, She was in India, they outsource to Canada and India so it would be difficult to see if there was construction in Fl.They are only going to react to things that they are authorised to fix. Call them and tell them that your modem goes on and off, forget the router for now, ask for the motorola 8500 series. You may have to ask for a supervisor and don't let them talk you out of it. You also should tell them that your intermittent issue happens wheather the router is on or off, since they don't understand unless they walk you through the basic troubleshooting, which is a waste of time. You are loosing your signal because the modem is droping the connection, you can also look on the Linksys home page, and see if there is a firmware upgrade for your router, but make sure you get the right version number of the bottom.The last thing to check is to see if they have "filters" on your line, they can also cause problems with the modem. If you have a private home or condo, there is a box that stands out someware on the lawn or off to the side. Usually its not locked. Pull off the top and see if you see silver cylindrical looking tubes about 3 inches long inline with your cable line going into the box. If so they may be causing the problem. I had 3 of their trucks on my lawn at one time, and they couldn't figure out what was wrong. ten minutes after they left I had everything running. The problem is subcontractors, are doing the work and you either get a good one or a bad one, you need to keep having them come out until they get it right. So just to go over it again, Modem, Firmware on router, Wiring coming in, Filters on the line. Get to a supervisor right away or you will have to tell the story several times. Also if they do come out, ask him what his meter is telling him your signal strength is. Cable is shared and if others are using their service at high load times, that is another reason that your connection must be perfect, or this is going to be ongoing. good luck
Posted on Mar 12, 2009
Geekman
  • 32281 Answers
SOURCE: I have a NETGEAR wire/wireless router MBR624GU. My
This Netgear has :-
  • LAN ports: Four (4) 10/100 Mbps auto-sensing, Auto Uplink™ RJ-45 ports (one Cat 5 UTP cable included)
  • WAN port: USB 2.0
  • Wireless: 802.11g Access Point auto rate capable up to 54 Mbps†
The modem needs to be connected to the WAN port, not to a LAN port.
Posted on Dec 10, 2009
govinda123
  • 2263 Answers
SOURCE: Every time I connect router I lose internet
If your computer is able to go online through the
modem, that means the modem is working fine.
This router WRT160N hs firmware issues.
Try to upgrade the firmware of the router.
Is there any computer connected to the router with
the cable.
If not then you will need to connect the computer
to the router.
Download the firmware of the router from the
manufacturer's website.
enter the model number. select proper version
number and download the firmware of the router.
Once you download the firmware, you will need to
open the router set up and upgrade the firmware of
the router.
After upgrading the firmware, it is recommended
that you reset and reconfigure the router.
Click Here for more information about router and
networking
Posted on Feb 27, 2010
nkrcs
  • 94 Answers
SOURCE: no dial tone on cisco 504G phone
to use an Ethernet phone you will need a VOIP supplier ( You will need to Google this for the country you are in ) . You will not be able to use it until you have these set up. Ethernet phones are not like a standard home phone which use your local exchange to route your calls they use servers on the internet to do that and route your call to landlines.
I hope this helps if so please give me a thumbs up
Posted on Jul 23, 2010
  • 55 Answers
SOURCE: have connected wii to cable via cisco asa 5505
Error Code: 52020 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Connecting directly to a modem:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
    Connecting to a router:
  1. Ensure that an Ethernet Cable is running from the WAN or Internet Port on the router to the modem. Power cycle the modem by unplugging it from the electrical outlet, waiting a moment, and then plugging it back in.
  2. Power off the Wii console, and insert the Wii LAN Adapter into one of the USB ports on the back of the Wii console.
  3. Run an ethernet cable from the Wii to a numbered port on the router.
  4. Power on the Wii console, and run a connection test through the Wii console's online settings.
  5. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's settings on your PC:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these as they're listed into the "Manual Setup" of the Wii console's internet connection, except for the IP address. The IP address needs to be different. Add 10 to the IP address and use that number in the Wii console's settings.
you can also visit this site for more information about your comsole tnxx please rate me if this help you...
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52020&system=Wii&locale=en_US
Posted on Aug 09, 2011
I have an old tv with comcast cable. I want to switch to a smart tv that has only been used with netflix. how do i connect smart tv to my comcast cable
Adding a smart tv just requires adding an ethernet cable to your internet connection to the ethernet port on the set. The smart services on the set us a broadband internet connection to work.
Jun 18, 2016 | Vizio 42 in. LCD TV
How can I set one router to connect with another
Easy way: Run a long ethernet cable from where the Comcast router is to the place you'd like to have the Linksys. Tell the Linksys not to act as a router or try to connect itself to the internet -- in this set-up, it's just acting as an access point. It probably needs to know the IP address of the router so it can send packets out to the Internet -- that information is called "Gateway" on my router. Feel free to add more detail to the question if that doesn't help!
Feb 18, 2014 | Computers & Internet
My landline is hook up to ciso an thats hook up to netgear how do i make calls out
If it's a cable modem you should have your phone landline connected to the cable model, if you have a "bundle". TV, Broadband, Phone with your provider. For example: I have Comcast/Xfinity bundle, TV, Phone, High Speed Internet. At the Comcast Modem it has a Phone jack RJ-11 for landline and Fax and a RJ-45 for my Wireless Access Point and Ethernet cable.
Jan 18, 2013 | NetGear WGR614 Wireless Router
Device code for cisco RNG 150
Ok I know the post is kind of old, I mean the person asking about wanting to find the code for comcast Cisco RNG 150, all depends what Bose system do you have, the system I got is Cinemate GS series II that comes with an universal remote, and the codes for the Cisco brand cable box, it doesn't specify model code only Cisco cable box, anyways the codes are, 01877, 00877, 01982, now the last code worked for my universal control, don't know if it will work with other Bose controls, one thing I found out while browsing is that someone posted a cinemate manual with some codes but not for Cisco cable box they were for scientific Atlanta that are boxs comcast uses for the digital preferred system, the Cisco is use also for digital preferred but it has a different code, out of the three codes I posted earlier the first two were the same as the codes for the SA cable box, but the third one 01982 worked for mine. I hope this information will help someone. CEVICHE!!!!!
Jan 13, 2012 | Bose Cinemate Digital Home Theater System...
I have just switche from comcast cable internet service to ATT thinking to save a little$ with bundling. My Linksys router worked fine with Comcast, but I cant get it to work with ATT ethernet. Does...
You have to use PPPOE and set it with your ATT username and password:
http://www.dslreports.com/faq/6890
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 13, 2010 | Cisco Lynksys Dual Band Wireless N Gigabit...
Router pasword
Default user names:
  • Linksys BEFW11S4, WRT54G: admin
  • Linksys EtherFast Cable/DSL Ethernet routers: Administrator
  • Linksys Comcast routers: comcast
  • All other Linksys routers: [none]
Default passwords:
  • Linksys BEFW11S4: [none]
  • Linksys Comcast routers: 1234
  • All other Linksys routers: admin
Dec 07, 2010 | Linksys Wireless-G WRT54G Router
I have an Arris modem from Comcast that gives me phone and internet service. Prior to going to Comcast for telephony I used a regular, off the shelf, modem and I could connect to my Direct TV sat box via...
comcast use 10.0.0.1 for ip address, I think
check direct tv box for internet settings for it's ip address should 10.0.0.2 maybe call directv maybe they could further.
May 14, 2017 | Arris Touchstone 450a (CM450) Modem
No dial tone on cisco 504G phone
Jul 23, 2010 | Cisco SPA504G IP Phone
Set up my comcast cisco box to my sony bravia and am getting a "no signal" message even though my cable in and hdmi connections are secured. please advise thx
Hi
Is this a new TV going into an old connection or an old TV going into a new connection? If this is a new connection I would get a hold of Comcast and make sure they have registered the boxes IP address. If this is a new TV then I would go into the menu and select the TV inputs. Go through these until you see an image. If still nothing then the new TV is defective. Good luck
Mar 13, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
How to connect tv to comcast cable box
If you only have the comcast receiver and a TV, take the input (wire from outside the house or outlet on wall) and screw that onto the input of the comcast receiver. Take another wire (or RCA, component connecters or whatever means the box and TV provides) and go from the output of comcast receiver to the input of the TV. Set the TV input mode (on the TV itself or by the remote) to whatever mode you hooked up the cables to (video 1, aux, video 2, etc) and you should see a picture. From there use the comcast remote to change channel. If you use the round cable (rg56 or rg59) you will not need any other connections between the TV and the box. The video and audio are broadcast on the same line. If you use RCA (yellow red white) connectors, yellow is video, white and red are audio) you will need all three wires from comcast receiver to TV. I hope this helps and good luck!
Nov 18, 2009 | Audio Players & Recorders
Televison & Video Logo
Top Cisco Televison & Video Experts
Are you a Cisco Televison and Video Expert? Answer questions, earn points and help others
