Question about Baby Gear
Where is the balboa institute recommended by dr phil?
Is Dr Oz and Dr Phil real Medical doctors?
Doctor Oz is an MD. Doctor Phil is not an MD.
Doctor Phil holds a PhD in Psychology.
Jun 15, 2017 | Health & Beauty
Ehat is Dr Phils website address? is the official website for Dr Phil.
Nov 17, 2016 | Computers & Internet
Replaced pump on my hot tub refilled it and error code Dr appears on my balboa control panel?
That error means that the tub was drained. Reset the controller and it will be fine.
Jun 17, 2015 | Garden
Are the people on Dr Phil actors??
The guests are not actors. They know what Dr. Phil will ask them and for the most part, what will happen. But they're real guests.
Jul 08, 2014 | Computers & Internet
Balboa spa codes
I found a listing of error codes on this website for you.
Apr 19, 2014 | Pool & Spa
Overheat errors
possible temp sensor bad if ok bad control board
Feb 25, 2013 | Balboa Instruments BALBOA VS500Z PUMP ,...
Balboa vs500/501/502 gs500/501/502 I just refilled spa yesterday and now I'm getting error codes HL and dr both indicate low flow issues, The water level was re-filled to where it's always been. Any help...
A lot of times you can get an air lock as the spa fills. All you need to do to fix this is open the drain valve for a few seconds till it runs just water and no air. Or start the pump wile the drain is open. This should fix your problem. Good luck.
Sep 04, 2010 | Balboa Instruments Duplex Digital Panel 2...
I have the Balboa 500Z pump heater kit. Its hooked direct to a mighty iron ( 120v) recirclulating pump. Ever since it was new, I keep getting lack of water vflow errors ( dr, then dy ) I have plenty of...
I have a 6 month old Balboa 500Z. I have noticed that the filter system tis running all the time 24/7. I have reset the filter cycle to run for 2 hours { F2 }. It still is running all the time. It dose not seem to make a difference what I set the cycle for it just keeps running
Dec 06, 2009 | Balboa Instruments Duplex Digital Panel 2...
Baby Gear Logo
67 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
