Question about As Seen On TV Living Pure Pro Series 4-in-1 Heater
Where can i buy a new fuse ?for 9000 livingpure heater
    Habit-Forming:
  • 195 Answers
What is the full model number?
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Posted on Jan 07, 2017
Where can i buy a new fuse for living pure heater 9000
Jan 03, 2017 | Televison & Video
Rear heater
check fuse
check if power is reaching the heater
check if ground is ok
measure the resistance across the heater
if its a blown fuse- replace it
if no power reaches the heater and fuse is ok - measure if power reaches the fuse.socket then the switch for the heater and so forth
if there is poor ground or no ground - wire up a new ground or fix the old one
if there is too high of a resistance across the heater - look for broken traces and buy a silver trace pen (one made for repairing heater traces)
if there is too low of a resistance - look for a short circuit
Feb 18, 2014 | 2004 Ford Windstar
Electric Water Heater blows fuse, but only every few years
Your residential water heater is not 9000 watts. Or it would blow the fuse every day and melt the wire. Instead, you have dual-element non-simultaneous 4500 watt water heater.
http://waterhatertimer.org/How-it-works.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Look at label for 'total connected watts'
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
25 amp breaker or fuse and 10 gauge wire is minimum acceptable for 4500 watt water heater.
http://waterheatertimer.org/Color-code-wire.html
Troubleshoot blowing breaker or fuse:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Why does it blow fuse once each year?? I don't know.
Fuses and breakers trip when overheating occurs on wire.
Each fuse or breaker is rated for heat, and over time, it will get hot and then cool and then get hot again ... this action weakens fuse or breaker.
To solve problem: install 3500 watt elements (and clean sediment out of tank). Wire will run cooler, and fuse will last longer. Whole fuse box will demand less power, and run cooler, and will last longer as a result. So there is less stress on electric service panel.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3500 watt element will heat water to same temperature, but takes longer. For example: 4500 watt heats 21 gallons per hour, while 3500 watt heats 17 gallons per hour.
Apr 28, 2013 | Water Heaters
How to replace switch on lakewood oil heater 9000
Where may I find a service place to replace a switch ?
Dec 02, 2012 | Lakewood Oil-Filled Electric Radiator...
Hatco c-9 booster heater won't heat, 1 amp fuse keeps blowing
that is in the control cicut the contactor might be bad and taking out cntrl fuse.unhook contactor control voltage by unplugging from contactor tape off the two wires put new fuse in turn on power if fuse does not blow replace contactor.if it does blow you will have to isolate the next thing in the control circut maybe the light.you can buy resetable 1amp circut breakers at grainger for test purposes.sometimes on people I know I will wire in those breakers for them no more buying fuses.
Apr 11, 2011 | Hatco Corporation Compact Electric Booster...
New saab 9000-1995-new to us. radio codes we
call friendly bodyshop ask them about codes
Mar 02, 2018 | 1994 Saab 900
Need new plate
I've gotton Janome 9000 needle plates at wwwifixmachines.com
they have both updated and older versions available.
Jan 15, 2009 | Janome Memory Craft 9000 Computerized...
As Seen On TV Living Pure Pro Series 4-in-1 Heater Logo
Top As Seen On TV Televison & Video Experts
Andrew Taylor
Andrew Taylor
Are you an As Seen On TV Televison and Video Expert? Answer questions, earn points and help others
