Do I get U Count points when I buy from Makro ??
I need a pin to buy stuff at makro
Register an account at Makro Store.
Dec 18, 2017 | Computers & Internet
Where can I find a user manual for a new Ellies 2.5kW pull start petrol generator bought from Makro in South Frica?
Powerlanddepot provaides this type of generators. you can all products at powerlanddepot.com This generator is running so good. This generator is capable of supplying enough power to on the refrigerators, fans, lights.
Oct 29, 2016 | Electrical Supplies
Could not find watch configuration file
best return it for a replacement if you can .
Nov 13, 2015 | GPS
2003 impala intermittent high idle with high iac count iac tested good
Before buying a ECM for the car I would do a smoke test on the vacuum line to be sure there is no leaks and causing the idle to very. Hope this helps.
Apr 17, 2017 | 2003 Chevrolet Impala
I'm using d-link dwl-3200 ap ( three) Received Frame FCS Error Counts indicate a problem? ___________________________________________ WLAN 802.11G Traffic Statistics Throughput Transmit...
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
  • As per the above there are error on Transmitting the packet and also for receiving the acknowledge packet.
  • Please check whether any disturbance in the link
  • Each PPP packet has a checksum attached to ensure that the data being received is the data being sent. If the FCS of an incoming packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
  • Another reason for seeing too many FCS errors may be that the remote end has stopped talking PPP.
Feb 27, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
Battery Cycle count of 801 what does this mean good or bad?
It means that you've probably had your Macbook about 4 or 5 years and have recharged the battery in full 801 times.
This is neither good or bad. It's just a fact used to determine how much you've used your Macbook on battery.
As long as you are getting an acceptable length of time while using your Macbook on battery, then you should be fine. At some point in the future, the battery will begin to fail and last for shorter and shorter amounts of time and eventually may even drop-out completely. At that point, you'll either buy a new battery for your Macbook from Apple or buy a new Macbook.
If this answer helps you to understand the cycle count (and it should), please rate my answer as either 3 or 4 thumbs-up (1 or 2 thumbs up are like saying my answer was useless or barely appropriate)
Thanks for using FixYa and Happy New Year!
Jan 03, 2011 | Apple MacBook Mac Notebook
Clouds in my TV
Hi it seems that the colour gun has gone faulty or the equivelent in an lcd tv. I purchased my umc from makro & I have never had any problems returning anything. As long as it is within the 12 month warranty. If 28 or more days have passed, contact makro or UMC & get an RMA number & you can get it replaced or refunded.
Jan 31, 2009 | Televison & Video
14 people viewed this question
jasbo
jasbo
