Question about One For All Televison & Video
I Have a jumbo remote with no code search button
It can switch 6 devices and the bottom 4 buttons (it has 42 in all)are as follows ,left red contrast - next green contrast + next yellow *- next blue *+ last on right TV-AV I have found an image of it on the web but can,t locate any instructions for it.Can you help? all it says on the back is complient to part 15 of FCC rules .Made in China.
  • One For All Master
  • 6,694 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.....
http://electro-medical.blogspot.com/
Posted on Jan 04, 2017
How do I get my Jumbo remote programmed?
Jan 04, 2017 | Televison & Video
How do i program the innovage jumbo universal remote
Jumbo universal remotes are essentially the same regardless of the name at the top. If you have a device you want to control, start by turning on that device. Press and hold CODE SEARCH until the red indicator stays on, then release the CODE SEARCH button. Press and quickly release the device button, e.g, TV. Point the remote directly at the device. Press the power button (in the upper right corner) repeatedly until the device responds, e.g., changes channel. Press ENTER and release to install the code. If no result, your Innovage jumbo remote may not have a suitable code available.
Oct 23, 2014 | Innovage Jumbo Universal Remote Control
How to program emerson jumbo universal remote to jvc tv model dvd component
Click here to download the user manual to Jumbo remote controls. it will have all details.
The common proceedings are:
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 21, 2012 | Televison & Video
I need the code for memorex t.v. and innovage jumbo remote
you can try using the built in code search on the remote
1.Turn on the TV
2.Point the remote at the device and hold the CODE SEARCH button until the LED light is RED
3.Press the TV button on the Remote
4. Keeping the remote pointed at the TV push the ON/OFF button until your TV turns OFF
5. When the TV turns OFF press the ENTER button on the Remote
6. use the ON/OFF button and see if it turns the TV on,
7. If not repeat steps until it works
Mar 05, 2011 | Televison & Video
Need to find code for Jumbo Universal Remote to use with Aiwa S2011 MTS television. Thanks for any help!
Hello
Aiwa TV is not lited on Jumbo Universal Remote codes. Anyway try out with these codes. Sometimes may help you.
Three digit codes for Aiwa TV with universal remote are:
195/ 196
Four digit codes for Aiwa TV with universal remote are:
0195 0196 0227 0269
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
NOTE: Switch OFF and switch ON your TV with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
OK
Jan 27, 2011 | Aiwa TV-S2011 20"
I was wondering if anyone could help in two problems the codes for thomson DTI6300 pvr box and a time 32" lcd L220 tv to be used with the jumbo universal remote. thanks in advance keith
Here is a link to the codes, but I suspect you already have them and your devices aren't listed.... http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/innovage/jumbo-manual.zip&area=other
So, you can manually code your jumbo as follows;
Turn on the device you wish to match with your remote. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red. Press the button on the remote for the item you want to program (TV, DVD, etc.). The LED light should blink once and then remain a solid red.
Press the On/Off button slowly until the device you want to program turns off. The LED light will blink once each time you depress the On/Off button. When the device you want to program turns off, press the ENTER button. The LED button will turn off and the code for that device will be stored in your remote.
Jan 06, 2010 | Universal Remote Control Remote Control
I need instructions and codes for Innovage Jumbo Remote
This is a link for a list of codes.
or
Code search setting is an alternative method to programming your device without using the code list
Turn on the device you want to set
Aim the remote control at the device
Press the decive button for the item you want to program
Press and hold the SET button until the LED light up solid red
Press the MUTE/SEARCH button. The LED will shut off first then light up solid red.
When the device turns off, press the OK button to store this code.
Code Retrieval
Press and hold the device button you want to display on the remote control
Press the NUMBER 1 then count the number of flashes
Press the NUMBER 2 etc
Press the NUMBER 3 ets
Press the NUMBER 4 etc
If the LED light flashes 10 times the number is 0
Nov 11, 2009 | Innovage Jumbo Remote Control
I have an innovage jumbo remote did not loose it!!! LOST THE DIRECTIONS TO PROGRAM IT.
You can program the Innovage Jumbo Remote by entering three digit codes, or by using the auto-search function.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Oct 31, 2009 | Innovage Jumbo Remote Control
CODE FOR TDE SYSTEMS UNIVERSAL REMOTE CONTROL
CANNOT PROGRAM THE TDE SYSTEN=MS JUMBO REMOTE WITH CODES FOR A CITIZEN TV
Mar 01, 2009 | Universal Televison & Video
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
