Question about Baby Gear
The lock will not open..seems to be jammed and will not turn. What do I do?
How do I fix a lock that is jammed?
Contact the builder of the doors of the Summerhouse or go to the lock companies website. There may have been a faulty batch or known fault identified on these locks you have fitted.
Alternatively contact a local locksmith who could give tyou advice..
Mar 01, 2015 | Locks & Locksmithing
Hi I have an iseo lock on my reasonably new summerhouse and although i have the key and the key turns both ways in the lock, apparently engaging and disengaging the lock on a single turn each way, i cannot...
You should be able to feel the lock disengage. Also feel the latch moving. If you can feel this, then the door is jammed, not the lock or handle. They do swell. You'll just have to force it open. You might try spraying some lube at the top and bottom, where you suggested it feels stuck.
Mar 01, 2015 | Cars & Trucks
Kwikset door lock jams inside and out.
Is sounds like the door settled or shifted and jammed the bolt in the jamb. I would put a pry under the door and gently lift while turning the key. That is only for the up and down but could be that the door needs to be pushed in or pulled out while turning the key. If you want to get real crazy just pop it off the hinges and investigate. If the lock still does not work with it free from the jamb then you will just have to replace the lock.
Jan 21, 2013 | Kwikset Locks & Locksmithing
Printhead cartridge jams
Hello, sorry took so long but, seems to be a paper jam or loose ink cartridge, open lid with unit unplugged and try and see any paper jammed in rollers or pieces of paper, then with that done and hopefully fixed but if not, close lid and turn unit on then open lid to access print cartridges make sure they are installed right and the right ones in the right slots if the cartridge unit don't move so as to load cartridges in try to gently pull it to position as a cartridge may have not been locked in or jarred loose.good luck hope this is of some help.
Dec 09, 2011 | Kodak   ESP5250 Es Printer
I have a Pixma MP 470 that says there is a paper jam. I have turned if off and unpluged it for a long period and have also put card stock through it but there does not seem to be a paper jam. Is there...
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 23, 2010 | Canon PIXMA MP470 All-in-One Printer
Left hand back door will not open. Seems to be jammed all of a sudden. Have taken off door panel, what should I look for now?. Central locking works on all other doors, and seems to be working on the...
there are 2 sets of rods one is for door lock the other is for door lach pull it one way or another which ever makes it move one of the will open the door
Aug 31, 2010 | 2005 Volvo V50
We have a bi-fold door in our kitchen. It has an ERA multi lock. The lock seems to have jammed, first we couldn't open it. Then it opened and I played with lock and now it is again stuck in lock mode but...
It sounds like the rack inside the centre part of lock has snapped, remove from door and you should be able to shake fragment out lock may continue to work without but may need a new gearbox.
Sep 15, 2009 | Locks & Locksmithing
Can not close the back cover
a Samsung tecahnician justed fixed it for me. The feeder (at the back cover) just in wrong position, turn it to the opposite way and he recommended that next time if the paper jam no need to open the back cover just turn the printer off and then turn it on, the paper will feed out. But it case you have done as he recommend and it still jam, open it would be possible. (the Feeder I'm not sure what it's call, it were 3 piece of black plastic)
Jan 28, 2009 | Samsung CLP 300 Laser Printer
Garage door wont open
There really is no way around this. You will have to break something to get in. The easiest thing to do is to drill out the lock bolts or the lock cylinder nad unjamb it or take it off to gain entry. Sorry for the bad news. Thanks BB
Nov 18, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Baby Gear Logo
61 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
