Power to the set but nothing comes on - Televison & Video
  • Televison & ... Master
  • 6,694 Answers
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jan 03, 2017
My JVC model. my JVC TV LT 42 EM 59 will not come on .I get no blinking blue light no power no nothing I get nothing I've tried to reset it in nothing
With no power it will not reset---if total dead unit you would have to first follow the power cord into the set to the line fuse it goes almost directly to---check the fuse first and examine the power supply board for damage or puffed up filter caps.
Dec 20, 2012 | Televison & Video
Dryer power is on. When I set the cylce and push start nothing happens. Already checked the belt and it is fine.
Have you check go see it you are getting a full 220v to the dryer, assuming it's electric. If there's only one leg of the power the control power would come on, but nothing else would work.
Apr 09, 2011 | Kenmore Dryers
TV will not come on by remote or power button
There is a problem inside the set. There is nothing that will lock the set up. I would start with the power supply. Thanks
Oct 28, 2009 | RCA 20F514TD 20" TV
Been setting in storage a year when all hooked up it starts up just fine then quits and sets there with the timer running but wont wash or spin or nothing wont fill with water
When you mention that it starts up fine. Do you mean that the machine initially takes in water, but then nothing after that. Or does it simply power on, but no water comes into the machine.
If no water comes in initially, then it is most likely your inlet valve.
If water comes in but no motor action, then it could be a raft of things. Disconnect the power source. Open the top hatch and the back panel. Make sure the drive belt has not come off during transport. Also check to see if no wiring connection has come loose. NOTE: Make sure the machine is off and disconnected from the power plug.
If you can't spot anything loose then it is best to get a service technician to diagnose the problem.
Ash
Oct 21, 2009 | Frigidaire GLTF2940ES Front Load Washer
Dead set
sub power comes from microp to front panel touch boards if absolutely nothing hapen you may not have this voltage.also there is a fuse were the power cord connects to power bd.clay
Mar 03, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
Panasonic CT-35HL43 36" TV has NO power
Something is shutting down the power supply, most likely from over current
Feb 13, 2018 | Panasonic TX-28CK1 28" TV
Stuck in suspend/sleep/standby... I think...
Take the battery out for a minute and put it back in. Don't plug the AC adapter in. Now turn it on. If it comes on go to 'settings' 'control panel' 'power settings' set everything to 'never' and make sure nothing is checked under the differant tabs. Ray
Jun 21, 2007 | NEC Versa SX Notebook
Won't turn on...
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
Dec 19, 2006 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
