Question about Sharp Office Equipment & Supplies
I am shahid i am facing a problem sharp photocopier model 5516 (u2-4)pls give me the reset code.
  • 120 Answers
SOURCE: how to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Posted on Jul 09, 2009
rezazadeh
  • 328 Answers
SOURCE: Code
how input code(# interrupt C interrupt)
Posted on May 30, 2010
  • 28 Answers
SOURCE: i have photocopy sharp ar-5516 and when i switch
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
press 14 and start key twice.
copier should restart normaly.
If not, then you have problems with the fuser, contact me to tell you what you have to do next.
Regards,
Adi
Posted on Nov 05, 2010
Testimonial: "thanks a lot it was very helpful"
muhaemin89
SOURCE: H2 problem sharp AR 5516
is that mean, I have going down to simulation by pressing # interrupt 0 interrupt then machine wil shutdown mode than press 14 then press start.
is that true? because I mess up with my copier cannot print because code H2.
Posted on Sep 30, 2012
intelsrinu
SOURCE: sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Posted on Apr 18, 2013
HOW TO FIX ERROR CODE 444 BLINKING FOR SHARP AR-5516?
http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5516-D-5520-D_OM_GB.pdf
May 20, 2014 | Sharp AR-5320 Black and White Copier
My Printer is displaying an H4 error
The error code H4 means that you have a problem with the fixing unit. It could one of the item's > The thirmistor or thermal fuse or the fixing heater lamp
Oct 05, 2012 | Sharp Office Equipment & Supplies
Sharp ar 5516 maintenance reset
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 driver free download for xp
Drivers for Sharp AR-5516 are available at Sharp Official Support site Click here and make selections as under: -
Select
1. Photocopiers
2. AR5516
3. Windows XP
Download the required Drivers/ Utility.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Aug 06, 2011 | Office Equipment & Supplies
Solution TO sharp photocopier ar-5516 4 H error
Press the following buttons fast: #, interrupt, C, interrupt, C, 14, Start button.
Oct 06, 2010 | Sharp Office Equipment & Supplies
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
How to reset u2-40 for sharp AR266 photocopier
Hello sir; I'm not recognize this model number please double check,but I give you closer one to reset;
1, press "program", "interupt", "clear", "interupt".
2, enter 16 press start.
3, turn machine off and back on .
Jun 02, 2009 | Sharp AR-M205 Copier
32 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
