Question about Ingersoll Rand Air Tools & Compressors
Ingersoll Rand vsd fault 37 - Ingersoll Rand Air Tools & Compressors
4 Suggested Answers
  • 205 Answers
SOURCE: We have ingersoll rand VSD
These VFD or VSD units do experience drive failures. If it is not covered under warranty it will be and expensive repair. You might try calling the IR Phone # that should be affixed to the unit. Some times they might recommend replacing an electronic board and supply it to you. Other than that replace the drive.
Posted on Jan 15, 2011
  • 205 Answers
SOURCE: what is a vsp fault 10 alarm Ingersoll rand
A VSD 10 fault is bus oscillation. Quickly rising and falling voltage. Recommend having power company check incoming voltage for oscillation.Voltage can not vary more than 3 percent or alarm is issued.
Posted on May 28, 2011
  • 42881 Answers
SOURCE: IR Ingersoll Rand 75 kw air pressure compressor. Set pressure reached cut off. But restart time VSD fault 41 come. What is this problem solution.please help
Contact Ingersoll/Rand through their website .
Posted on Oct 10, 2015
Plase help!VSD fault 2 Problem with Ingersoll Rand Air Compressors nirvana n37 37kw
Vsd fault 2 is a current imbalance. Check your current readings and compare them to those on the intellysis display they should match, also check for a imbalance in amps. After that it gets more complicated using board diagnostics etc
Sep 12, 2014 | Air Tools & Compressors
Please!!!VSD fault 7 and VSD fault 1 Problem with Ingersoll Rand Air Compressors nirvana n37 37kw. thanks!
Vsd fault 7 is a fault with the hall effect sensors inside the motor, more than likely they will need replacing.
Sep 10, 2014 | Air Tools & Compressors
VSD fault 7 Problem with Ingersoll Rand Air & Gas Compressors nirvana n37 37kw
these compressors are costly even the parts to maintain.I would first check if you cooling fan for the vsd drive is working which is located in the electrical panel of the compressor.A failing fan or one that has failed would cause this fault
Mar 22, 2014 | Ingersoll Rand Air Tools & Compressors
plz any one help us vsd 7 fault and the compressor does not start and the fault appears
Mar 21, 2014 | Ingersoll Rand Air Tools & Compressors
Fault vsd 44 on nirvana nm 37
Check fuses on the pl5 board, if these are ok you will need to call an Ingersoll Rand technician to do a 348 diagnostic test on the drive, could be a number of things including faulty motor
Aug 28, 2013 | Ingersoll Rand Air Tools & Compressors
Ingersoll rand nirvana problems vsd 1
Vsd 1 fault is over current, check if motor turns ok, if this is ok it could be a number of issues that will need to be diagnosed by an Ingersoll Rand technician.
Jul 07, 2013 | Air Tools & Compressors
VSD Fault 23
Vsd 23 is a motor under speed problem. Check motor turnes ok, if not it could be a number if faults including the hall effect sensor that detect motor speed, you will need to call a Ingersoll Rand technicion in to do a 348 diagnostic test.
Apr 18, 2012 | Ingersoll Rand Air Tools & Compressors
Air Tools & Compressors Logo
169 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
