Question about Car Audio & Video
Is there a dvd available for the dumping ground kids program
Default code for dvp-ns315 parental control
There is no such code available, if there where kids would google it and the "V" chip would be worthless to control what your kids watch on TV.
Jan 20, 2012 | Televison & Video
Tip
Does not make espresso Superautomatic
3 things
1. Dumps the grounds dry. = Dosage lever or knob is to the max. Reduce by 1 click.
2. Dumps wet and pumps runs for a few seconds. = Needs to be programed. Hold coffee button until it starts to dispense liquid but only when it gets to the amount you want for that button, release the button.
3. Dumps wet and pump runs for 1 minute, then ventilate comes on. = Blockage in the brew head (needs to be taken apart and cleaned) or bent gate valve on injector nozzle (replace gate valve).
on Dec 17, 2009 | Coffee Makers & Espresso Machines
How do I bypass the parking brake connection for the Sony xav 60 so the dvd will play all the time. My kids would love to watch it while on the move.
Hello! you can install a switch with brake wire on one side and ground on the other...Or you can permanently ground the wire...
Guru.....Saailer
Jun 01, 2010 | Jensen VM9510 Car DVD Player
123CopyDVD.exe has stopped working......
First, Uninstall your program using Add/Remove Program in Control Panel.
Start Menu -> Control Panel -> Add/Remove Programs
Note: Be aware of shared files don't remove them, it will affect other programs that use that file
After Uninstall, restart your computer
Then start again, proceed to installation of your program.
Jan 26, 2010 | Navarre 123 Copy Dvd Gold for PC
Dual xdvd 8625 double din emergency brake bypass
you can ground it,then enter the code 26604 after u insert a dvd real dvd then press stop twice then enter the code it should work
Jun 06, 2009 | Dual XDVD8170 Car DVD Player
Panasonic RR-US430 - physical memory dump
http://www.fixya.com/ThreadView.aspx?prdid=202200&thid=822714
Jul 23, 2008 | Panasonic RR-US360 Digital Voice Recorder
Panasonic CQ-VD7005U in dash dvd 7'' touch screen
Connect the light blue parking brake wire coming out of the back of the radio to the black ground wire also out of the radio to the black ground wire on the wiring harness.... Basically just ground the parking brake wire.. Itll work, I promise. I have the 7001u.
Dec 03, 2007 | Panasonic CQ-Vd7001U
Screen won't play movie
sound like the wire to the parking brake may not be getting a ground.if it not get a ground it will no show a picture on the screen. it so you cant watch the dvd while driving.
Feb 11, 2007 | Concept DVD-168C Car Video Player
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
