U8 error code on a mitsubishi model puya12nha6 out door unit what is causing this unit to keep going off on this code
3 Suggested Answers
  • 53 Answers
SOURCE: Error code U8-6 on Xerox 5320 copier
U8-6 suggests low or No light being picked up by the ccd.Does the Scan lamp come on at all?
Yes.?..clean mirrors and underside of platen glass (there is a white reference strip which must be clean
N?.lamp failure or reset the thermostat push button on lamp carriage (disconnect power, this can bite!)
Posted on Nov 16, 2007
relaga58
  • 158 Answers
SOURCE: p8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
Posted on Jun 01, 2009
Ciac inverter error code "U8
two error codes i get "H6" and "U8" after u8 system will not run at all..carrier is no help and service people have no ideas
Sep 17, 2013 | Heating & Cooling
Split ac error code u8 what problem
3 possibility for U8 Error code:
1) Signal receiver faulty
2) PC board fails
3) Indoor blower fan motor faulty
Aug 03, 2013 | Soleus Powered By Gree 8000 Btu Portable...
U8 detail 61
U8 is the ADF Set-up Error. This error is displayed when Pick roller unit is locked in the upper position, release(lower) the Pick roller unit to resolve the error. Secondly, if the hopper is over loaded, reduce the document load on the hopper.
Hope the above information is helpful.
Thanks,
Scancare
Dec 21, 2011 | Fujitsu fi-5900C Pass-Through Scanner
I am using xerox work center pro428 .now it is not working error message showing code U8-3
Hi, I can't find that specific error code in the documentation on that model of machine, however, in general in Xerox machines U8-3 means that your exposure lamp is blown or has a problem
Aug 19, 2011 | Xerox WorkCentre Pro 428 Copier
Xerox 5314 throwing a U8 code
It is the problem your copier heater unite conector is life out change it and solve your problem
Jun 30, 2009 | Office Equipment & Supplies
P8 eroor code
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Replace Drum Unit
U8 is an error for the paper transport unit., its the piece where the bypasss goes to you exit tray.
Aug 06, 2008 | Panasonic DP-C264 Copier
Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Mar 14, 2008 | Dishwashers
dear sir please check the exposure lamp unit may be it is dusty so clean it or check exposure lamp circuit fuse etc....
Oct 07, 2007 | Office Equipment & Supplies
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
