U8 error code what could be causing unit to be going off on u8 error code
2 Suggested Answers
  • 53 Answers
SOURCE: Error code U8-6 on Xerox 5320 copier
U8-6 suggests low or No light being picked up by the ccd.Does the Scan lamp come on at all?
Yes.?..clean mirrors and underside of platen glass (there is a white reference strip which must be clean
N?.lamp failure or reset the thermostat push button on lamp carriage (disconnect power, this can bite!)
Posted on Nov 16, 2007
Ciac inverter error code "U8
two error codes i get "H6" and "U8" after u8 system will not run at all..carrier is no help and service people have no ideas
Sep 17, 2013 | Heating & Cooling
Split ac error code u8 what problem
3 possibility for U8 Error code:
1) Signal receiver faulty
2) PC board fails
3) Indoor blower fan motor faulty
Aug 03, 2013 | Soleus Powered By Gree 8000 Btu Portable...
Avanti 928 Treadmill U8 error
try to LUBE the deck belt, with silicones or wax, . If the problem persist TIME to replace the old deck board.
However, adjust The REED switch + speed sensor.. See the owner manual for to locatea. otherwise download free from
www.fitnessmanualsonline.com
God bless you
May 20, 2013 | Bowflex Treadmill Series 7
U8 detail 61
U8 is the ADF Set-up Error. This error is displayed when Pick roller unit is locked in the upper position, release(lower) the Pick roller unit to resolve the error. Secondly, if the hopper is over loaded, reduce the document load on the hopper.
Hope the above information is helpful.
Thanks,
Scancare
Dec 21, 2011 | Fujitsu fi-5900C Pass-Through Scanner
Getting error code u8-3
Exposure lamp blown, lamp terminals contact or regulator
Cek Kabel Optic.
Aug 22, 2011 | Xerox WorkCentre Pro 428 Copier
I am using xerox work center pro428 .now it is not working error message showing code U8-3
Hi, I can't find that specific error code in the documentation on that model of machine, however, in general in Xerox machines U8-3 means that your exposure lamp is blown or has a problem
Aug 19, 2011 | Xerox WorkCentre Pro 428 Copier
Kyocera fs-c8008n printer ,error show:call service 2010:0067501
2010 is the error - main drive motor starting error.
Main drive motor starting error
• No FG (Frequency generation) pulse
is entered within the predetermined
period since ASIC (U8) on the engine
controller PWB (KP-992) has issued
a motor activation signal to the main
drive motor.
0067501 is the number of prints on the printer.
solutions:
Replace the engine controller PWB (KP-
992).
Replace the main drive motor.
Check if the drum unit or primary transfer
unit rotates smoothly. Check for broken
gears. Replace if any.
Check the continuity of the harness
(2CK2711). Check the insertion of
connectors.
992).
Feb 19, 2010 | Office Equipment & Supplies
Xerox 5314 throwing a U8 code
It is the problem your copier heater unite conector is life out change it and solve your problem
Jun 30, 2009 | Office Equipment & Supplies
Replace Drum Unit
U8 is an error for the paper transport unit., its the piece where the bypasss goes to you exit tray.
Aug 06, 2008 | Panasonic DP-C264 Copier
dear sir please check the exposure lamp unit may be it is dusty so clean it or check exposure lamp circuit fuse etc....
Oct 07, 2007 | Office Equipment & Supplies
20 people viewed this question
k24674
jasbo
jasbo
