Question about Golf
My Par Car runs great. I drove it a short distance & it died. The beep was continuous. I shut it off waited a minute and it started back up. Any suggestions? Nothing in the manual! Thanks. TS
SOURCE: 96 cavalier 2.4 starts runs great -chokes
Check the crankshaft position sensor. If the plug is loose or the sensor itself is bad it will cause similar problems
Posted on Aug 26, 2008
SOURCE: keeps shutting off
I have a LASKO 5565 model fan and had a similiar problem. Cleaned the whole unit, thinking it was tripping the safety breakers, and it still would turn on and off. The control console was completely unusable. So then I thought that it was maybe the squat switch located on the bottom of the unit. I quickly deduced that not to be the problem and continued following the wiring. Just above the fan there is a 1/2"X1/2" thermostat. Upon touching it I almost burned myself. For some reason the unit was grounding here and cause the thermostat to heat up and shut the unit off. I took the thermostat out of the equation and the unit works great.
CAUTION: If you pursue this action you must understand that you no longer have a thermostat and the unit is now simply just a heater. It will either be on at full blast heat or it will be off. Good luck.
Posted on Nov 20, 2008
  • 360 Answers
SOURCE: The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Posted on Mar 19, 2009
  • 4 Answers
SOURCE: Car Runs and Loses Power and Quits Running
Try cleaning the fuel pump filter. Under the seat behind the driver lift the carpet and you will find a round cover with six screws remove the cover. The fuel pump is directly below unscrew the retaining round plate and remove the pump. At the base of the pump is a small filter if it is covered in black muck that's your problem. clean and replace. job takes about 10 mins good luck. please let me know how you got on!
shauunswbc@aol.com
Posted on May 08, 2009
greg_margo
  • 1959 Answers
SOURCE: Dies after running about 2 minutes
It's got all the symptoms of a leak in the fuel line. You may want to start backward at the tank and work your way all the way to the carb to find it but it would be surprising if it was something else. All the best.
Greg
Posted on Jun 15, 2009
What do you think is wrong
intermittents are sometimes hard to diagnose out !! and this seems as one , im curious though what made them wiggle the relays and fuses ?? was there a previous problem there ?? depending on year of manufacture of car , is weather or not the cars own pcu can help diagnose what made car stop , as later models "remember " what there last condition was that shut off engine , of course this requires diagnostic equipment to see this info that typically car owners don't own , but a qualified service tech does and knows how to use it to find your problem
Aug 05, 2016 | Cars & Trucks
99 Volvo V70 seems to stall and vaporlock, after running. The car shows an ETS light, which I understand to be the Electronic Throttle Sensor. It has shown this light for over a year, but has not given...
change your fuel filter ..your vehicle will run but your fuel pressure is weak ..also after this clean your fuel injectors by pouring injection cleaner in your gas ,,it will correct itself..Also ,,if none of what I stated works ,,Spark plugs and new spark plug wires needed ,,Lastly your fuel pump
Oct 23, 2013 | 1999 Volvo V70
Just purchased a 94 Sunbird SE for my son (today) Started fine. Drove for 15 minutes. Shut it down and it sat for 1 hr. Started again after registration and insurance. Drove for 10 minutes. Stopped once...
Take it back to where you got it and make them refund your purchase price. If they refuse and you finianced it go to them, There a law called "The Lemon Law" that makes it unlawful to sell something like that. Sounds like you sure bought one. Don't do anything to it just get hold of the place where you bought it and tell them to come get their junk out of your yard! dhgill1949
May 22, 2011 | 1994 Pontiac Sunbird
Car stalling out and bot starting after being driven for awhile.
mcdevito75 Here, It"s possible the ignition Module is going bad, no way to test and if so, one day the car will not start at all.----------It can also be a vapor loc, wher the fuel is evaporating before it reaches the cylinders. Best Bet, have your local shop check both these items.
Jan 01, 2010 | 2000 Dodge Stratus
The 96 park avenue will start great and run great. No security light comes on and everything runs smooth. No bucking or hesitation. A great ride. Then all of a sudden it will die. Lights stay on and radio...
It cannot be the VATS system. The TDM, that is the core of the VATS system, is engaged only at the time you start your car. I have a problem exactly like yours on my 95 LeSabre and just discovered it is the alternator that sometimes charges and sometimes doesn't and when it doesn't, the battery's voltage goes lower than a certain threshold and the computer (PCM) is unable to work anymore and shuts down the engine. Took me months to discover this!
Dec 29, 2009 | 1990 Buick Reatta
My unit started beeping continually, I changed batteries, but
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
The woman was very friendly. Great customer support!
-=dån=-
Aug 29, 2009 | Kwikset 907 907-L03 Lifetime Polished...
I need help with my 94 cutlass ciera V6!
I AM LEANING TOWARDS A POSSIBLE BAD CRANK POSITION SENSOR OR A POOR CONNECTION IN THE IGNITION CIRCUIT, PERHAPS A BAD IGNITION MODULE. CHECK TO SEE IF YOU HAVE POWER GOING IN THE MODULE AND GOING OUT. ALSO CHECK FOR SPARK WHEN IT IS HOT. I HOPE THIS HELPS. THANKS FOR USING FIX-YA AND FOR AN HONEST RATING. PLEASE FEEL FREE TO KEEP ME POSTED ON YOUR PROGRESS. BEST OF LUCK.
Aug 26, 2009 | 1994 Oldsmobile Cutlass Ciera
shauunswbc@aol.com
Mar 10, 2009 | 2002 Land Rover Freelander
Golf Logo
608 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
