Question about TruTech Televison & Video
Can I hook up the trutech model KLv3112 to a regular TV for bigger picture and or cable through it
  • 814 Answers
SOURCE: coaxial cable hook up
You have to buy a adaptor for coaxial to television antenna hook-up. One side is used to hook up the cable to and the other side is to hook up to you televisions antenna's screw hook-up. These adaptors can be bought in most electronic stores and you should be able to find them on line. Just use google for cable to television adaptors. I hope this helps you with your problem.
Posted on May 17, 2009
romsky79
  • 822 Answers
SOURCE: No picture on TV
check LCD connector or video cables.
Posted on May 30, 2009
  • 2187 Answers
SOURCE: trutech tv - no sound, but have picture
Check if you would have the same if you use a different signal source. Another DVD Player, a playstation or other AV devices. The source or the TV may not be understanding each other, one may be sending analog signals while TV is only recognizing digital.
Posted on Oct 10, 2009
SOURCE: How do you hook up regular coax cable to the TV?
You simply need an "F" connector to "Belling-Lee" converter. about $4.00. At any Radio Shack, Antenna shop. This screw onto the end of the existing antenna connection & makes it so you can plug it into the Socket at back of set.
I have included a link that has a picture.
http://cgi.ebay.com/1-Coax-TV-Adapter-Connector-PAL-Male-to-F-Female_W0QQitemZ110386773163QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item19b3907cab#ht_683wt_1139
Posted on Feb 16, 2010
SOURCE: comcast dta remote codes for trutech klv3112
I have a Trutech 10 inch under cabinet DVD/TV and needed the codes for the new Digital Adapter that Comcast is forcing everyone to move to. The short answer is that there isn't a single code that will work for what we all need. After much research I have an answer. It's largely unsatisfactory, but its somewhat of a work around. If you use code 10451 you can get the channel up, channel down, the number pad and the "last" button to work. To get volume functional, change the volume lock on the comcast box. To do this:
1. With the TV on, manually set the volume to a medium high setting
2. With the comcast remote, press and hold SET until the red light blinks twice.
3. Enter 9-9-3 (red light blinks twice)
4. Press and release the digit 1 (red light will blink 4 times)
Now, in addition to channel control, you have volume control. I can't do anything about the power button or other functions. However, this at least makes the remote functional.
Good luck to all!
Posted on Apr 29, 2010
Trutech TV/DVD klv3110 spacesaving kitchen manual download
Hiya Rosa,
you can try the manuallslib site they have most of all manuals from old mixing gear through to modern tv/DVD players,
Hope this helps
Kevin.
May 23, 2015 | TruTech KLV3112 10 in. LCD TV/DVD Combo
I have a TruTech KLV3112 10in LCD TV/DVD combo and the DVD door will not open. What do I do?
I would try unplugging it for 5 minutes and then power it back up.
There may be a reset/eject button that you can depress with a pin or paperclip near the door much like an old Macintosh had.
I have long since abandoned this unit and have a Skyview 13" in my Westfalia. You might have to do the same if you need to run DVD's.
Mar 02, 2015 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Problems
Turn off, Turn back on or switch sources.
Jun 20, 2013 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Hook up to digital TV antenna indoor passive
Please check if the antennae is connected with right cable and the dipole is good. If so search the channels avaiilable and if there is no signal then it is possible that the TUNER is faulty. check using another TV with the same antennae or check the RF input using a VCR or TUNER.
Oct 30, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
It's not a problem ... I just want to know what the power requirement is for the Trutech 10" Undercabinet LCD TV/DVD Combo - KLV3112
Hi, it will be in the 9 to 12 volt range probably with about a 2 amp rating. Buying the kind of " universal " power supply with interchangable plugs should do the trick. The actual " adapter " you buy will more than likely be marked as follows 100-240v~ 0-12v dc ( or a solid vertical line over dashes) 2.5a followed by a polarity indicator. Always be careful too when inserting new plug-it should fit snugly but not so that you need to push with much force. thanks for letting me try to help, I hope this was of some assistance. Good luck, Prodzilla
Apr 13, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
I need to purchase anothe remote for my Trutech under cabinet DVD/tv combo. could i get the number to call Trutech or anybody that can sell me another remote please..
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
How can you manually change the channel on the tv so i can hook it up to a satalite dish that calls for it to be on channel 3 or 4...it is on channel 2 and will not allow me to change it up or down
when u connect a satellite disk to your tv set, you bypass the tv channels, you can control on satellite receiver, not the tv. you might have a different cable to connect satellite, as scart or rca cables, when you power on the receiver, the tv switch to aux(AV1) automatic.
Feb 18, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
I have a spacesaving kitchen 10
I have the same problem as the above question. The picture goes off and there is only sound
Feb 17, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Transformer has failed in my Trutech M#KLV3112
The transformer should have the input and output rating labeled on the unit itself. Such as input 110vac, output ...... dc.
Jan 14, 2009 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
