Question about Konica Minolta BizHub C650 Copier
Where can i find the fusing unit with pictures about c-3102 bizhub c650
  • Konica Minolta Master
  • 6,696 Answers
The fusing unit is located on the right side of the machine, open the right side door, not the duplex door the bigger one. you will see a shinny belt do not touch as that puts the image on the paper. The fuser unit is right above it. It can be hot so power off to remove it. your code is for the fuser did you try to reset it??
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Posted on May 07, 2017
4 Suggested Answers
  • 24 Answers
SOURCE: what fuse to use to reset the fusing unit on a bizhub c352
If you are in the UK you can buy the fuser fuse from RS components it is part number : 541-3221 http://uk.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=541-3221
Posted on Jun 25, 2009
Bizhubman
  • 108 Answers
SOURCE: how to reset the transfer unit (fuse?), do you
Hope this helps. Make sure you remove the waste tank prior to taking out the transfer belt. Belt is removed by two screws inside right door and sliding the unit out.
Posted on May 17, 2010
amer201166
How to reset the bizhub c 250
Posted on Sep 16, 2014
I have a problem with my konica minolta bizhub c451 giving error Code C 3102
c3102 for Fuser Unit abnormality.
Check Fixing Unit and its Gears , also the drive gear on body.
Reset by Switch On Holding Utility/counter Button for 10 seconds.
Touch TROUBLSHOOT and restart by Power off and on
Jul 07, 2017 | Konica Minolta Office Equipment & Supplies
What is the code for rectify the printer if it has atrouble code of c-3102
Replace the fusing UNIT.
TO Reset follow this procedure: IF the code comes BACK DO NOT RESET AGAIN DEALING WITH THE FUSER IT CAN CATCH ON FIRE!!!! That will ruin a perfectly good day!!!
Procedure:
For parts try this site for starters
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Dec 12, 2015 | Konica Minolta BizHub C650 Copier
Bizhub c650 cyan toner chip error
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Aug 30, 2015 | Konica Minolta BizHub C650 Copier
Konica minota c650 Printing balck baground copies
replace the black image unit. and ensure modification lock is installed to ensure proper connection if you pull out the black image unit is there black developer piled up in the rear???????
Jun 20, 2015 | Konica Minolta BizHub C650 Copier
Reset error code 3102 on Konica Minolta bizhub 6500
drive issue for the fusing motor, get a technician to look at it
Jun 25, 2014 | Konica Minolta Bizhub C 6500 Copier
My colours do not align on my bizhub c650
run the registration procedure. do you have any oil can showing on the bottom of the control panel P-21. P-28 etc
Apr 16, 2014 | Konica Minolta BizHub C650 Copier
Bizhub c650 fehlercode c3102
Check the fuser unit HOT PART!!. Rollers can not turn, replace the fuser unit
Jan 21, 2014 | Konica Minolta Office Equipment & Supplies
C 3102 - Communication sistem setting error.To reset :
Turn OFF the copier,keep pressed Utility/Function key and turn ON.Keep pressed the Utility key when Trouble reset message apaire on screen.Touch the message,turn OFF ,wait 1 minutes and turn ON.
If the code persist remove the fusing unit and under fuser unit in right side upper is located 2 sensors under plastic knob.Clean the 2 sensors.
Dec 22, 2013 | Konica Minolta Office Equipment & Supplies
Getting a c2559 error code when replacing a cyan image unit
was this third party??? if so replace the image with Konicaminolta unit
Nov 19, 2013 | Konica Minolta BizHub C650 Copier
Konica Minolta BizHub C650 Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
