Follow instruction inright cover - Office Equipment & Supplies
How do i send fax where do i put the paper
Paper inright hand side tray, at top , Must not put paper in Printing unit at the front. To send Fax , use Fax mode, enter receiver Fax phone Number , Press any Black ot Colour button to send
Mar 14, 2015 | Canon PIXMA MX340 Wireless Office...
My varbatim card 32 gb is not decated
On a Windows computer
  • Plug card in
  • Right click Computer > Manage > Disk Management
  • If the card is detected here right click it and delete any volumes on it.
  • Right click it again and select New Simple Volume. Defaults are fine.
If Windows doesn't see it at all you may need a linux live cd to access and format it with Gparted.
If it can't be detected in Linux the card is probably dead.
Jan 26, 2013 | Verbatim Electronics - Others
I have scanner LEXMARK X2690 How can I use it to scan a file?
Follow this steps on how to scan docs/files
> open the top cover, load original document facedown on the scanner glass.
>close the top cover to avoid dark edges on the scanned docs
> Make sure printer is connected to computer and both printer and computer is on.
> From the printer control panel press scan
> Follow the instructions in computer screen.
If u are using Windows
> Repeat 1 and 2 on top instructions,
Do one of the following;
> In windows vista click select all programs and then select the printer program folder from lists.
> In Windows XP click start Programs or all programs and then select the printer program folder from the list.
> Click Lexmark Productivity Studio
> On the main screen click scan
> follow the instructions on the screen..
Nov 24, 2010 | Computers & Internet
Sounds like the 'Clear misfeed' symbol. Open the front cover and follow the pictorial diagram instructions to check your paper feed path for jammed paper. Remove misfeed, and close covers. This should reset your machine.
Jan 30, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Fuse and power supply look ok to the eye slight static sound on audio tiny flash intermitent inright corner on video, any clues? power diods check good ,nothing looks hot or burnt There is a second board...
Your power supply on the dc output should have the floowing DC voltages, 5v, 12v, and 24v. Just start probing the connectors of the power supply. 24v is needed for the backlights inverter board, 12v for sounds, 5v for logic board.
Dec 09, 2009 | Audiovox FPE3206 32 in. LCD Television
Unable to change cartridges no instructions with printer
Open the front cover.The carriage will come out.Open the covers and pull out the old cartridges.Then remove the tapes from new and pull in.Close all covers and follow the instructions on the screen of your monitor.
Sep 28, 2009 | Lexmark Z640 InkJet Printer
We have the following message on screen. Insert black or photo print cartridge inright stall. We have cleaned contacts, renewed both cartridges, and still have this message. Can you advise as to the...
first make sure that your printer is directly connected to the wall socket.
Now unplug the power cord from thew back of the printer & press and hold the # and 3 keys together and plug in the power cord back into the printer (partial reset). check if it resolves the problem, if not then unplug the power cord from thew back of the printer & press and hold the # and 6 keys together and plug in the power cord back into the printer (semifull reset). check if it resolves the problem, if not then. take out all the cartridges from the printer & unplug the power cord & plug it back in without inserting the cartridges. once the printer powers on it will give you an error "ink cartridges missing" or it will ask you to insert the ink cartridges, then insert the cartridges in the printer 1 by 1 starting from the black (hard reset). This should resolve the problem. please let me know the same
Aug 20, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I want to change sim card in my nokia N72
I think u have some problem with removing back cover of ur phone
To change sim card follow below instruction
1) Turn off your mobile phone (press switch off button on top of the phone)
2) Remove back cover by pressing unlock button on the cover & slide cover upwards gently (please take care you would not force the camera cover)
3) Remove Battery From the phone & u will see ur current sim or sim slot
4) Check instruction & insert your sim
Mar 30, 2009 | Nokia N72 Cellular Phone
Aficio MP1500 displays'' follow instruction in cover to remove''
Nov 21, 2008 | Office Equipment & Supplies
26 people viewed this question
