Question about Bush Refrigerators
Bush fridge freezer water not draining away
  • 1,193 Answers
Not draining away from where? There is probably a plugged drain hole or hose somewhere.
Posted on Jan 03, 2017
Water accumulating inside the fridge
hi kostas.
Condensation runs down the back of the fridge and collects in the gully sitting at the back of the fridge where the water is then channelled through the drain hole into a container which sits on the compressor, it's then evaporated away.
How to Stop Water Collecting in Your Fridge ' eSpares Water accumulating inside the fridge Google Search
Nov 07, 2017 | Refrigerators
I have a bush fridgefreezer, i have a problem with water not draining down the drain at the bottom of the fridge compartment. it then floods under the do i stop that from happening, its und
The water is supposed to drain from the coil area every time the fridge goes through a defrost cycle to get ice off the fins. The water should drain out into an evaporating tray adjacent to the motor/pump unit. Obviously it is not draining, so when the freezer freezes again the remaining water freezes and eventually creates a mini glacier in the fridge which floods every defrost cycle. The culprit is accumulation of years of gunk in the drain tray or drain tube or a little funnel like apparatus that feeds into the evap. tray. The fix is as follows: Shut the fridge off, unplug it and gain acces to the cooling fins/drip tray area. (I found a good video that explains the process sep by step for the kenmore freezer down type. I would link it but dont have a clue how to do that) . Carefully chip away at the ice with a wooden spatula -- not a crow bar. When most of the ice is gone pour hot water to melt what is left and get it flowing down to the evap tray. You may send too much water down there but such is life. Clean up the water that has run all over the kitchen. Dry out the fridge with a good table clothe and put it back together. Your fridge/ freezer will work now, but it will ice up again. Time for part 2 of the fix. Pull the fridge out, remove the back panel, and with the aid of a light follow up from the evap tray and find the little funnel affair. Pull it off and fill the sink with warm soapy water and use a bottle brush to scrub that rubber thingy. It is unreal how much crud gets stuck in there over the years. If I had had access to a new rubber drain piece I would have gladly thrown the old one out skipped the scrubbing. At this point the fridge is as fixed as it is going to get. It is unreal how many fridges are thrown out over this flooding issue and the fix is quite easy as you will see.
Jan 10, 2015 | Bush Refrigerators
Find the water drain hole/pipe and clean it thoroughly with a pipe cleaner or other softish flexible rod. That should allow the water to drain away. Make sure back of the unit is clear and clean so water drains and evaporates off properly.
Jul 31, 2014 | Fisher Paykel ActiveSmart Fridge - 17 cu....
Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Feb 04, 2010 | Refrigerators
Water dripping within the fridge
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Jul 18, 2009 | Refrigerators
The hole that drains water away at back of fridge is blocked
Ok you need to defrost this unit eg unplug and leave all doors open for 48 hours then get some "flexy curtain wire (white plastic coated, used for hanging net curtains) this wire is perfect for getting up or down the fridge drain.
Please rate my advice
Mar 25, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
Water under veg bins
Hi. thanks for the question . the problem you have is with the drain tube, from under the freezer wall ,in the fridge. that tube is clogged up . pull fridge away from wall. locate the drain hose at the drain tray. clean. also clean all coils behind fridge thanks the appliance doc
Sep 30, 2008 | Kenmore 20.6 cu. ft. Top Freezer...
Hi I have a whirlpool (IKEA) CBI 651 fridge/freezer, the condensation drain on the back wall of the fridge part is not draining away the water. Have tried to clean it out with red 'widget' supplied with no...
Try pouring some boiling hot water down the drain. If anything blocks the drain even slightly it will slow down the water and then freeze it. Air temp in the freezer is 0 degrees or close to that. That small of a hole it freezes quick. I'm not sure of the style of fridge this is. Side by side or top mount freezer. You are able to get to all drain pipes. If not boiling water. A hand steamer works great too.
Jan 20, 2018 | Whirlpool Refrigerators
Water on the bottom of the fridge - then turning in ice
drain is blocked. to check, pour water into drain gulley in fridge and it should flow away. to clear, push sometthing flexible down the hole. good idea to pour dilute bleach down hole now and again
Mar 19, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
Top Bush Refrigerators Experts
Joseph Coppeto
Joseph Coppeto
Are you a Bush Refrigerator Expert? Answer questions, earn points and help others
