Question about Cell Phones
To enable my phone to work again - Cell Phones
How to repair network problems
Obvious first question: Is your pne's wifi enabled? Check settings, somtimes they 2unable" themshelves
Obvious second question: does you Cell phone provider have signal currently? Maybe you should go to a hotspot and try your phone there.
So if your phone is enables and you have signal and can't connect network, the network adapter is not working.
Reset your phone and try again. If still nothing, guess it has some serios problem which exceeds technical capacitiy of a Q/A website answer, so you should take it to an authorized repair site and ask them to diagnose your phone
May 11, 2015 | Cell Phones
When setting up email I just get the message "pop3/smtp service is not enabled. Enable the service and try again". How do I enable it? my email works fine on all my other devices
you have to enter the pop server and the password you your account on the device under the mail settings for that account.
Mar 13, 2015 | Android Huawei
I have a 4G LTE phone that is only picking up 3G service in an area confirmed to have 4G LTE service. LTE setting on phone is enabled. Mobile Network access points configured correctly. Turned on "Airplane...
Check to make sure that the 4g is configured properly on your phone first. I don't know your phone, but even if you toggled airplane mode nothing would have changed if 4g wasn't enabled to begin with. If that doesn't work, try contacting your carrier.
Mar 10, 2015 | Cell Phones
Mf190 driver for android
Instructions
    • 1
      Pull the battery out of your Android phone if an app freezes while you are using it. Reinsert the battery after one minute. Replace the battery cover and restart the phone. Launch the app again.
    • 2
      Check whether your phone's data connection is active if the app is data-dependent. Touch "Menu," and then tap "Settings." Touch "Wireless & Networks," and then tap "Mobile Networks." If the "Data Enabled" field is not checked, touch it to enable it. Launch the app again.
    • 3
      Verify that the app is up-to-date. Touch "Market" from the phone's home screen. Press "Menu" on your phone and touch "My Apps." Scroll down to the "Not Installed" section. If the app has an available update, touch the app. Tap "Update," and then touch "Accept and Download." Wait for the update to complete, then launch the app.
    • 4
      Uninstall and reinstall the app. Tap "Menu," and then touch "Settings." Touch "Manage Applications," and then tap "All." Touch the app that is not working, and then tap "Uninstall." Reinstall the app from the Android Market and launch the app again.
God bless you
May 24, 2013 | Cell Phones
Sim card puk code n. 8264084361
*#7465625# = Check the phone lock status
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7,
it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then
the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
It may not work in all phones, but with standard its working ;)
Feb 14, 2012 | Cell Phones
Blackberry pearl 8130 issues
take the battery out of the phone then place it back in the phone and try again, if it freezes again then you have a software problem and you will need to take the phone into a repair center and have it diagnosed.
Sep 19, 2008 | Verizon Communications BlackBerry Pearl...
Displays test mode
To exit test mode, turn off phone.
Press *3001#12345#. Scroll up 1 to FIELD TEST (some phones may say NET MONITOR instead of FIELD TEST) and SELECT. Scroll to ENABLED and press OK. Turn phone off and then back on. Signal strength is the upper or lower left number. After test mode is enabled it will stay in your regular menu. To easily get in or out, press MENU, up 1 FIELD TEST and SELECT or OK. Dial 00 to get out and 01 to get back in.
Jul 03, 2008 | Cell Phones
Sony k550i bluetooth problem
Hai, i too had this same problem friend.. I tried many ways and nothing worked.. Finally i got my mobile re-installed through a service center which made my bluetooth work again.. You also try the same .. Hope this solution would be help full.
Jun 09, 2008 | Sony Ericsson K550i Cellular Phone
Bluetooth
in this h.set BT automatically switches off after few seconds if not in use.it protects ur h.set from viruses.
u can increase this period from BT settings in h.set
Oct 09, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
