Question about Pool & Spa
VX chlorinator cant adjust timer settings. EG I can put in timer 1 to start say at 1100 but cant change run time from 1 hr to 4 hrs
catriver
  • 878 Answers
SOURCE: Washer won't stop!
Viv, hopefully it's just your filter thats clogged with lint and stuff. You will have to remove the front lower panel and the pump filter cover will be right in front. It just unscrews and pulls out. These models have a pressure switch that will not allow the machine to advance into high spin if it detects water in the tub. This is an easy job, just grab some towels and be ready for some water when the filter cover comes off. Clean out the stuff and see it fixes the problem..Catriver..post back.
Posted on Mar 05, 2007
tom19511
  • 1601 Answers
SOURCE: HP compaq d530c timer running fast
you may check and see if it's set to the "internet time" -> "automatically syncronize with an internet time server", if there you have a wrong server, then it'll reset your time wrong, or if you have another timezone set in windows, than it'll update to that timezone.
secondly, if it's a hardware related issue, than it can be the battery
Posted on Jan 09, 2008
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
escapement
  • 2334 Answers
SOURCE: 24 hr utc display is not synchronised with the rest of the watch.
Here is the link to get full instructions how to set or reset your watch (paste it into your browser):
http://www.citizenwatch.com/CUK/English/technicalinfo.asp?caliber=C650&ModelNumber=JR3060-59F
Choose: Interactive Settings Instructions.
You need a pair of speakers or earphones connected to your PC as all instructions are visible and audible.
Do not forget to rate, please.
Posted on Jan 06, 2009
  • 297 Answers
SOURCE: CLOUDY SALT WATER POOL
salt does not solve your problem.
People do no realize that all the salt does for you is that it eliminates having to pour regular chlorine in.
Everything else stays the same as a normal pool with just plain ole h2o
The dilema is that intex filters are to small for the job that needs done especially in your case now that you have the dreaded green monster
your solution is to first get it cleared up
shock your pool with 2 gallons of liquid chlorine and then filter filter filter
You will need to brush the dead algea and vaccum once or twice a day for a couple of days and you must clean that cartridge 3-4 times a day with the garden hose
you will be surprised how much green it will trap
once pool starts to clear and the chlorine level starts to come back down from Mars you can start using your generator again.
you will need to find the amount of time thatorks for you but 3-4 hours will not cut it in the hot weeks
Chlorine consumption is due to #of bathers, heat ,sun, rain so any given day will dictate a different amount of generation needed keep it high so you do not get algea again about 3.0
you also got algea because you were not stiring up the pool enough you again need to filter filter filter every day
try to find some of my other postings with more specifics
Posted on Aug 13, 2009
I dont no how to set the timer to 24 hr clock
change to 12 clock
however a 24 hour clock has the same times up to midday -- midnight to midday --- the hours are 1 to 12 oclock after midday you take 2 off the reading and it is the same time as a 12 hour clock
so 1300 is 1 o'clock, 1400 is 2 oclock ,1500 is 3 o'clock
1800 is 6 o'clock 2400 is midnight
the minutes are the same regardless so 1.30 is 1.30 after midnight or 1330 after midday or 1.30 after midday now for example --if you want the timer to start at 6am you set the timer to start at 6 am to switch off at 8 am set switch of at 8 am
it you want the timer to start at 6 pm set it at 1800 and switch off at 10pm set it at 2200 hrs
Jan 22, 2017 | Hardware & Accessories
How long should you run system
Always start high and work your way down...You want to maintain a 3ppm chlorine level..
Start by running a 12hr pump cycle with 10 hrs of chlorination... Check you chlorine level after 2 days and try to hit a target of 3ppm and after that, lower you cycle to maintain that level. For small pools, could be as low as 6 hrs pool pump, with 4 to 5 hrs chlorination??? I hope this helps you.. Good luck..
Aug 27, 2011 | Intex Automatic Salt Water System for ...
Hi I have ab 18x52' intex above ground pool with klear saltwater system, but I have algae in the bottom of the pool, please tell what to do to clean it without emptying the pool, and can i use any...
Get ready for a full weekend of cleaning your pool :) This is the chemical free method...
1st... Start with a clean filter...So clean your filter...
2nd.. Vacuum your pool and get most of the algae up from the bottom and sides.. Go slow so you do not stir up the algae. Make sure you use the vacuum attachment with brushes..
3rd..Clean your filter...
4th...repeat step 2 again...
5th... Clean your filter...
6th... Brush your pool with a pool brush to loosen the remaining algae..
7th... Set your pump timer for 12 hrs and your chlorinator for 10 to 11 of those hrs... and run for 3 days...
8th.. Check your water and see if has cleared and the algae is almost completely gone.. If so, check your free chlorine level and adjust your cycle down if at the required level..
9th.. if your chlorine level is not at optimal, run at the 12 hr cycle for 3 more days and check..
10th.. After water is clear and free of algae, clean your filter and adjust your cycle down to control your free chlorine level...
Good luck and hope this method works for you.. It has for me for over 2 years with my Intex Salt Water system...
Please take the time to rate me and write a comment... really appreciate!!!
Aug 03, 2011 | Intex Automatic Salt Water System for ...
My pool is cloudy and I added clarifier and it still won't clear. I checked the salt count and it's reading 1100 ppm. We have a 15 foot round 48 inch deep pool. I also shock the pool weekly...
1st... Your salt count should be at 3000 ppm... For your size pool, the start-up salt needed should be about 95 to 110 lbs..
2nd... Run your pump for 24 hrs without the chlorinator after you have reached the 3000 ppm to properly disolve the salt and use only "pool salt"
3rd... Set your pump at 12 hrs and your chlorinator at 10 to 11 of those hrs until you have reached the desired chlorine level.
4th.. After your pool water has cleared, within 2 to 3 days...clean your chlorinator electrolytic cell and adjust your time down to maintain the proper chlorine level..
Hope this helps and if it does, please rate and comment....
Good Luck!!!
Jul 31, 2011 | Intex Automatic Salt Water System for ...
Just purchased and installed Intex salt water system. It shows low flow and now, after 5 days of installment, the water is completely green (expecting Swam Thing to come out!) I need your guidance to...
Seems like you may not have the pump and the salt chlorinator in sync... If your water is dark green and not a big pool, you may want to drain and refill, if you have a large pool, you may want to shock and then try the following...
1.Make sure you have added the correct amount of salt...
2.Set your timer for your pump for 12 hrs.
3.Wait 15 minutes and then turn on your intex salt water system..
4.Set you hrs of operation on your salt water system for 10 to 11 hrs...
5.After running the system for 3 days, check your chlorine level..
If water clears and chlorine level is high, adjust the time.. You will have to re-sync the pump and chlorinator.. If the pump turns off before the chlorinator finishes it's cycle, you will get a "LOW FLOW" alarm..
I hope this helps and good luck.. Please rate and comment on the information provided.
Jul 26, 2011 | Intex Automatic Salt Water System for ...
The walls and bottom are getting slick what should we do to solve the problem?
This is an indication that your unit is not producing enough free chlorine...
Big pools require up to 12 pump hrs with 10 chlorinating hrs. (depending on outside temperatures) and electrolytic cell must be maintained clean. If your unit is clean and you have the correct salt level, try this;
Brush your pool with pool pump and get all that slick stuff off.
Clean you filter...
Set your pump to run 12 hrs with 10 hrs of chlorinator. You will see results in 2 to 3 days..
Clean your filter again..
After pool water clears and chlorine level raises, adjust time as needed..
Hope this will do it for you. If it helped, please rate!!
Jul 20, 2011 | Intex Automatic Salt Water System for ...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
Aug 13, 2009 | Intex Automatic Salt Water System for ...
We switched to the saltwater system and the water is cloudy
hello way too much for me to type if you want to call I can go through it have a pad of paper and pen ready
Mark
586-625-2300
Jul 19, 2009 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
