Question about Refrigerators
What does the err code EF mean on my fridge door
    Top Expert:
  • Refrigerators Master
  • 47,683 Answers
Google it MAKE and error codes
Posted on Jan 03, 2017
What does the error code SY EF mean on an Electrolux French door refrigerator?
Hello Suzanne, thank you for your post!
I understand that your Electrolux refrigerator is displaying an error code of "SY EF". An "SY EF" code stands for an evaporator fan circuit failure. This could also be a miscommunication with your refrigerator and I would advise performing a reset on your refrigerator. You can reset it by disconnecting the power plug from the outlet for roughly ten minutes. If that does not help correct your issue you may need to replace your main control board or a wiring harness. For proper disassembly and repair of your refrigerator I would recommend having a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Mar 23, 2015 | Electrolux Refrigerators
What does a Ef code on a Electrolux fridge mean? We have replaced the control board and the evaporator fan motor.
Hi Valmon Va, I appreciate your post!
I see that your Electrolux refrigerator is displaying the error code "EF" and you have replaced multiple parts. "EF" stands for evaporator fan circuit failure this could be a possible problem with the control board, evaporator fan, or wiring between each component. I would suggest consulting with a professional technician for a diagnosis because they have available tools to review each component and assure proper voltage to each piece. I hope this is helpful. -Matt
Dec 04, 2014 | Electrolux Refrigerators
Fault code EF is flashing on my Electrolux fridge FSC23R5DSB6. What does this code mean?
EF on the Electrolux refrigerator digital display means "evaporator fan."
The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Turn the power off on the digital display and carefully unplug the refrigerator from the power source. Leave the refrigerator unplugged for three to five minutes. Plug the refrigerator back in and give the refrigerator a few minutes then turn the power button back on. Press the default button on the display and see if the EF code goes away.
Electrolux recommends that you do not plug the refrigerator into an outlet that has a reset button. If your refrigerator is plugged into one of these outlets, try plugging it into another outlet and see if the refrigerator resets itself.
Hope this helps.
Jul 21, 2011 | Refrigerators
What does "Sy EF" mean on dispenser led?
Error Code SY EF is the System Evaporator Fault.
This usually means there is NOT enough air flow over the sensor, this can mean a faulty sensor, or fan.
Above is the latest service sheet to do with your machine, you need to check this.
Hope this helps (remember to rate and commnent this)..
Jun 03, 2011 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
On the freezer and fridge temp display there are the codes SY and EF. My manual doesnt give any trouble codes.
There is either something wrong with the fan or the computer. But the only thing you can do is go through the owners manual if you can't correct it with that you will have to call for warranty service. If you go any further then that you will void the warranty.
The short answer is that EF on the Electrolux refrigerator digital display means "evaporator fan." The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Hope helps.
Apr 07, 2011 | Refrigerators
Err 01 EF-S 17-85MM
The flat printed cables inside the lens unfortunately develop small cracks over the years and this causes the lens to fail. The repair is NOT easy, you have to tear down the lens all the way to it's base components and replace the flex cable on the aperture diaphragm. The cable and the diaphragm are available online, but again it's not a simple repair and most people should not attempt it themselves.
Thomas Drayton
Owner Darntoothysam com
May 25, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Err 99
err 99 means there is moisture inside of the camera, probably inside the hot shoe
Aug 25, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
HOBART AM15 DISH WASHER ERROR(E1)
After checking the service manual, I find no code for E1. There is a P1, or other E codes. Please list ML number.
Jun 14, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
