Question about Acer Computers & Internet
Which buttons to press on my acer laptop to start a golf dvd disc is in slot
  • Acer Master
  • 3,003 Answers
You will need a program to run DVD's on your computer.
If you have Windows the easiest choice would be Windows Media Player
Navigate to Control Panel and type in "Default" run down the list and select "Windows Media Player"
When I insert a DVD in my Acer I automatically get a menu come up
(Windows 10) giving me options of what I want to do with the DVD including "Play" .......Duh !!
If you need more help give some information on your OS
Earlier OS I used to have to go to Computer and the DVD drive should be visible - right click on it and see if "Autoplay " comes up
Posted on Jan 03, 2017
Dvd is stuck in my ACER laptop how can I get it out
The Acer 5610 has an emergency eject hole to the right of the eject button on the right side of the computer. Find a paperclip and unfold it (or small allan wrench), push the end of the paper clip into the hole until you feel pressure. Press firmly and the optical disc tray should come slightly out of the machine. Grab and pull the tray out (gently). This should work even without power to the drive on any machine tray optical drive, if the tray mechanism is undamaged.
For a slot-loading optical drive, it's a bit trickier. You can try sliding another object into the slot and using it to pry or lift the stuck disc. The safest option is to use another optical disc or credit card sized item and double-sided sticky tape. Put a piece of the tape on the item and then remove the paper from the other side of the sticky tape. Slide the item into the drive with the sticky tape towards the stuck disc (down for most computers). Once far enough into the drive, lower your item and press the tape firmly onto the stuck disc. Lift up and try to pull the stuck disc up and out of the drive.
I hope this helps.
Oct 26, 2011 | Acer Aspire 5610 Notebook
I have an Acer Extensa, problem is dvd disc doesn't seem to spin when I load it into slot. Always gives me the no disc detected window. R> U>
first go to the ACER web site and download the lattes drivers for your particular notebook. could just be a driver issue. if that does not work then the DVD drive may have gone bad.
Jun 10, 2011 | Acer Extensa 5420-5687 Notebook
I can not ecject the disc
hi there,
do the cd-driver have a tray or is it a slot where you push the cd in?
First off, Shut the computer down turn it on and then fo to the BIOS. (for most computers it's F2, for some it's Del or F10) to know how to do it on your computer when you turn it on and see the ACER logo check which button needs to be pressed so you can enter the SETUP.
Here's how you do it, From shutdown turn the computer on immediately start tapping the required button (F2, F10, Del etc.)
once in the Bios try pressing the eject button and see if the disc will come out.
If it doesn't:
For CD drives that has a tray: check if there's a small hole that you can punch a paper clip (that's the emergency eject button)
For Slot drives: Grab something that will fit in the slot and would allow you to pull the cd out.
Hope this helps!
Jun 02, 2011 | Acer AOD250-1694 (LU.S690D.056) Netbook
I have ran into a problem with my Acer Aspire 7520g. I started the laptop as usual and it started no problem. I then left the room and when i returned the laptop was switched off. When i now try to boot it...
Ok, you need to boot from your DVD with a Widows, install boot disc, inserted, and boot up on that DVD, then do a startup repair. OR... Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 22, 2010 | Computers & Internet
I can't put dvd disk into Dell Vostro 1310
1. Switch off the laptop
2. Press the power button to switch it on.
3. Instantly after pressing the power button, start pressing " F2 " key on the keyboard to enter the BIOS setting.
4. Now press/touch the " eject button " of the DVD drive and now you are done, you will get the disc out.
I stole this from http://www.tech-tweak.net/2009/11/how-to-eject-stuk-dvd-from-slot-load.html
Mar 17, 2010 | Dell Vostro 1310 Laptop Computer PC...
Where do you put a disc to download a recovery management program
there are usb CD/DVD drives (CD/DVD drives that plug in via the usb slot) and they are usualy pretty inexpensive dependong on the brand. but make sure if you get one off ebay, craigslist, ect that it comes with the installation/driver cd
if it does not you can sometimes download the software.
hope this helps
Jan 08, 2010 | Acer Aspire 4720 Notebook
I have an Acer Aspire 5720, ive had it for a year now and it is starting to slow down. I have lost the booklet to it and i need to do a master reset on it. Ive already backed everything up im just finding...
This was taken straight out of the manual for your model, which can be found here.
Acer eRecovery Management is a tool to quickly backup and restore the system.
You can create and save a backup of the current system configuration to hard
disk, CD or DVD. You can also backup/restore the factory default image, and
reinstall applications and drivers.
Acer eRecovery Management consists of the following functions:
1 Create backup
2 Burn backup disc
3 Restore and recovery
This chapter will guide you through each process.
Note: This feature is only available on certain models. For systems
that do not have a built-in optical disc burner, plug in an external
optical disc burner before entering Acer eRecovery Management
for optical disc-related tasks.
When using Acer eRecovery Management, you may be prompted to enter the
Empowering Technology password to proceed. The Empowering Technology
password is set using the Empowering Technology toolbar or when first running
Acer eLock Management or Acer eRecovery Management.
Create backup
You can easily create full and fast (incremental) backup images of your system
configuration to hard disk from the main Acer eRecovery Management screen.
Note: Fast (incremental) Backup is only available after a Full
Backup is made.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 In the Acer eRecovery Management window, select the type of backup you
want to create using Full or Fast.
3 Follow the instructions on screen to complete the process.
83
English
Burn backup disc
Using the Burn Disc page of Acer eRecovery Management, you can burn the
factory default image, a user backup image, the current system configuration,
or an application backup image to CD or DVD.
2 Switch to the Burn Disc page by selecting the Burn Disc button.
3 Select the type of backup (factory default, user, current system,
application) you would like to burn to disc. Choosing to burn a user backup
will burn your most recently created backup image to disc.
4 Follow the instructions on screen to complete the process.
Note: Create a factory default image when you want to burn a
bootable disc that contains your computer's entire operating
system as it was delivered to you from the factory. If you wish to
have a disc that will allow you to browse the contents and install
selected drivers and applications, create an application backup
image instead — this disc will not be bootable.
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
Dec 20, 2009 | Acer Aspire 5720 Notebook
Where do you insert a disk in a laptop
Check in right side of laptop .
You find i small button press it so you cna ejct it.
Also you can find with my computer .
open my computer thne right clcik on your cd drive icon then click on EJECT so your disk drive is eject.
Put your disk there.
Let me know if you need more assistanse.
Thanks.
Aug 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
