Question about Garden
Sharpening angle for MS 390 - Garden
  • 43 Answers
The angle for cross cutting which includes felling and logging is 30 degrees. If you are aiming to do ripping (cutting into planks so cutting down the grain) then set the angle to 10 degrees.
Posted on Jan 04, 2017
What is the sharpening angle for Stihl MS 390 chainsaw
That depends on the use the chain is being put to. If it is for normal cross cutting like logs and felling then setting the chain teeth at 30 degrees is likely to be ok. If it is only for ripping - like cutting planks then set the chain to 10 degrees.
Don't forget to ensure All teeth are the same length otherwise the saw will try to cut in an ark - like a banana. Also don't forget to set the depth gauge on each tooth otherwise you will just be producing dust.
Jan 03, 2017 | Stihl Garden
How do I find a parts manual for a Stihl MS290 ?
You Google pretty much exactly what you wrote and you get this
[PDF]STIHL Chainsaw Illustrated Parts Lists n Workshop Service Manuals thebakeliteradio.com/sawspares.com/Stihl%20MS310%20Service%20Manual.pdf
  1. Cached
  2. Similar
MS 290, MS 310, MS 390. This service manual contains detailed descriptions of all the typical repair and servicing procedures for this power tool. As the design ...
[PDF]STIHL MS 290, 310, 390
en.stihl.ca/p/media/download/en-ca/MS_290.pdf
  1. Similar
Apr 19, 2006 - MS 290, MS 310, MS 390. English. BA_. SE .... Manual. !Warning! Because a chainsaw is a high-speed .... and the function of the parts of your.
Stihl MS 290 STIHL FARM BOSS ' Parts List - ManualOwl.com
https://www.manualowl.com/m/Stihl/MS-290-STIHL-FARM-BOSS/Manual/401004
  1. Cached
  2. Similar
Stihl MS 290 STIHL FARM BOSS ' Parts List - Page 1. STIHL MS 290, 310, 390 A Zylinder MS 290 Cylinder MS 290 Cylindre MS 290 Zylinder MS 310 Cylinder ...
Stihl MS290 Parts List and Diagram : eReplacementParts.com
www.ereplacementparts.com/stihl-ms290-chainsaw-parts-c-162329_162330_182548....
  1. Cached
  2. Similar
Need to fix your MS290 Chainsaw? We have parts, diagrams, accessories and repair advice to make your tool repairs easy.
Stihl MS290 Parts
www.barrettsmallengine.com/stihl/ms290.html
  1. Cached
  2. Similar
Find parts in the Stihl MS290 chainsaw parts list below and find where to purchase them online.
Stihl MS290 Repair manual ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
  1. Cached
  2. Similar
Nov 4, 2008 - 20 posts - ‎18 authors Hi, I am new to this site and was looking for some help on rebuilding an MS290. I have the replacement cylinder and piston but need tips on ...
parts manual for Stihl MS290 Google Search
Dec 18, 2016 | Stihl Garden
What angle to sharpen a Lenox Chain Saw?
Typical sharpening angle is 30 to 35 degrees.
There is a handy little file holder available with these degrees marked on it. If you can get one, you should be able to determine what angle was on your chain to begin with.
My personal preference is 35 degrees.
Jun 18, 2015 | Garden
Chain saw sharpening angle
For cross cutting is 30 degrees and if you only do ripping it is 10 degrees.
Apr 22, 2015 | Poulan 16" 38cc Gas Chain Saw P3816
What is the edge angle when sharpening a knife?
This is the angle between the blade and the stone.
Jan 24, 2013 | Kitchen Appliances - Others
Why is my poulanpro 20 cutting at angle, what is proper sharpening angle. thanx
The manual should give the proper sharpening angle--the main thing is to make sure that all teeth are sharpened to the same angle. If you remove the bar and chain, look at the outer edges of the chain groove around the whole bar--you may find that the bar metal has worn is such a way that the outer edges are flared out beyond the surface of the bar. This flare tends to grip the cut and cause it veer off to one side. The cure is to file down this flare at about 45 degrees so that nothing projects. Hope this helps!
Jan 07, 2011 | Poulan Pro Chain Saw 46cc 20"
When I sharpen my chain with the timber tuff electric sharpener the chain cuts on an angle what am I doing wrong??
I will wager if you place a protractor on the bar you will find the right and left links are at slightly different angles (one side gets more bite). It only takes a little difference. The usual suspect is the guide on your sharpener. Some grinders require an offset because the wheel is offset more to one side than the other.
I hope you found this helpful.
Lou
Jan 18, 2010 | Electric Chainsaw Sharpener
Need sharpening angles
The angle is 30 degrees.
May 02, 2009 | Garden
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
