Question about The Home Security
My cctv dir was all working now i turn on the monitor and it lists all the 8 cameras but i get no images
2 Suggested Answers
mohamedhe59452
  • 133 Answers
SOURCE: DVR recorder for CCTV camera. Is not working. It says on the monitor cable not connected and no display. Monitor, cameras , DVR, adapter for cameras all working. I tried every thing.
try to change to VGA monitor or you could hold 5sec on ESC ,F1 or exit button
Posted on Feb 25, 2016
Will a HP 1740 monitor work?
you may choose another resolution in live monitor in DVR setting
Jan 21, 2016 | Zmodo 8 Channel H.264 Surveillance...
Outdoor Digital Wireless 2 CCTV camera System 7" LCD monitor DVR Record to SD TF but recorded playback poor what can I do please I am 81
Try recording in a higher quality than standard and see 2hatcthe results are.some of those are low resolution cameras and you won't get a wonderful image out of them.
Jun 28, 2015 | OUTDOOR Home Security
Foggy cctv image on 2 out of 4 images
Try using the camera on one of the good channels. If its still foggy its the camera, if it clears up problem is in the wiring etc of that channel.
Jan 17, 2015 | Cameras
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
Where can Ifind help for installing a Ouku brand 4 channel cctv dvr?
I had exact same problem and it took forever to fix but I did fix it. If I plugged the camera into the tv it worked but when I tried going through the dvr no picture at all. The problem was the power supply cord to the cameras. It was bad, I happen to have another one and that was it. All cameras working!
Dec 30, 2012 | GW Security Home Security
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
No picture on my tv from cctv camera
it is neither clear what sort of output your cctv cameras produce, nor what sort of input your dvr accepts. but, for the most part, dvrs record digital tv signals, whereas cctv cameras output analogue signals. so, even though you may be able to plug a cctv camera "straight" into a tv via a scart connector, it is unlikely that any scart connectors on a dvr have the necessary circuitry to accept such signals.
May 24, 2009 | Sharp Cameras
Installed wireless cctv in horse stables 4 mt x 6mt dont seem to
the gain is turned up to much this is washing out the camera
another possible cause is the auto iris lens is either not set properly or stuck open.
if you are using a "bullet" camera that may not be adjustable without opening it up and removing the camera from the aluminum housing.
its usually a tiny screw that you turn up or down. could also be that the CCD or cmos image chip is dying
Mar 11, 2009 | Ktl Cctv CFB2056IR Black and White...
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
Problem
it isnt the infra red.
on you dvr machine there should be settings or settings on the camera for mirror and flip.
these are features on better cameras and are normally on the camera body, but veiwable on the cctv monitor. they should be menu driven.
I hope this will be of help
Neil
Oct 21, 2007 | Samsung Digimax A50 Digital Camera
Home Security Logo
32 people viewed this question
Top The Home Security Experts
vince
 MikeWang
MikeWang
Level 1 Expert
Are you a The Home Security Expert? Answer questions, earn points and help others
