I have a Daewood window unit aircon heating and cooling 24 000btu
The problem is that it works well on cooling for 15min and suddenly switches to heater for 1 min and back to cooling for a short period it tends to do this continually JayWhat could be the problem as a call out technician was unable to diagnose the problem
Joe_Rex
  • 114 Answers
SOURCE: Short Cycling
COMPRESSORS HAVE AN INTERNAL T-STAT TO PROTECT THE WINDINGS ... SOME THING IS CAUSING YOUR COMPRESSOR TO RUN "HOT" THIS WILL KICK "IN & OUT" THE COMPRESSOR DURING COLLING OPERATION AND HEAT MODE (IF IT IS A HEAT-PUMP). 1ST THING TO EASILY CHECK IS THE CONDENSOR "OUT-SIDE" COIL. (CLEN BOTH WHILE YOU ARE AT IT). THESE FANS PULL THE AIR IN AND A BLOW OUT THE COIL .... ALL THE DIRT WILL BE ON THE INSIDE. 2ND THING IS THE FAN ITSEL OVER HEATING AN TURNING "OFF" ON ITS OWN "BUILT-IN POTECTION T-STAT". THIS WILL GIVE YOU THE IRRATIC OPERATION YOU ARE DESCRIBEING. I TEND TO THINK IT IS YOUR FAN MOTOR ... EASY TEST. TURN "OFF" EVERYTHING BUT THE FAN. SET IT FOR MANUAL "RUN ALL THE TIME" POSITION. THE FAN SHOULD NOT KICK OFF !!! IF IT DOES YOU FOUND THE PROBLEM. IF IT DOES TURN OFF IT CAN BE A WEAK CAPACITOR. UNITS VARY ON WETHER THE CAPACITOR IS FOR COMPRESSOR/FAN OR HAS A SEPERATE CAPACITOR FOR EACH. CAPACITORS ARE NOT EXPENSIVE. HOPE THAT CAN NARROW YOUR PROBLEM DOWN
Posted on May 07, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Magic Chef MCO153UW
The cooling fan is a must!
Otherwise, the magnetron will be ruined, and that drives up the repair cost.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order parts here: https://www.mcappliance.com/partorder.aspx
To contact Magic Chef about getting an *authorized* servicer, see: http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 04, 2008
daddyo742001
  • 70 Answers
SOURCE: Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Posted on Jun 28, 2009
  • 506 Answers
SOURCE: sherwood r-871 reciever audio works for 15min and
There could be a cold solder joint somewhere in the audio signal path. Finding this will be a difficult task since you will need a schematic and layout. One thing you can try to do to find the problem though is get a can of freeze spray from an electronics supplier. When cold solder joints heat up they expand and break contact. When hit with freeze spray they contract again thus making contact.
Posted on Feb 11, 2010
  • 3 Answers
SOURCE: TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Posted on Apr 18, 2010
How to trouble shoot Daewood air conduitioner
clean intake filter. if already cleaned, have system recharged or replace unit. air comes into the unit through the front and out the top vents,, if block or restricted it wont cool. if the air flow is good its how cold the evaporator is. so either freon level is low or compressor is bad.
May 15, 2014 | Newegg Daewoo Dwc0520fcl 5000 Cooling...
Panasonic inverter aircon R410 A goes to timer all the time
You have to use the remote in service mode to find the error code. Hold the 'check' button in with a paperclip for about 5 seconds and "--" will be displayed on the remote. Press timer up or down will change the error code displayed. When you hear the main unit start beeping quickly for about 4 seconds, that is your error.
Nov 03, 2017 | Panasonic Heating & Cooling
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
I have a GrandAire and the aircon works fine; when I turned the heat on, it seems to work fine (warms the house), but the fan in the outside unit is not spinning when the heat is on...is this a problem?...
I think your unit is working in good condition. If you keep in cool mode the out door fan runs to condensate the heat in condenser by taking fresh air from the ambient. And when you keep heat mode, definitely the ambient temp will be too less.I fit takes from their then compressor will get frozting and it couldn't work properly. Depending on pressure increase, the fan will automatically run and stop. Don't worry. Thanks.
Dec 16, 2010 | Heating & Cooling
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Sudden brownout
hi,
it has a small microcomputer which will shut off if /or error if the voltage parameters are too far out(brownout,surge) carriers are a higher end machine, better parts, should be fine..
jm
Jul 27, 2017 | Carrier Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
