Question about Polaroid 2611-TLXB TV
I have a poloroid tv 19 inch LCD FXM-1911C.
When I plug in the power cord (12 volt but might not be the same one) I get a picture for a litlle while then I get volume but a black screen. Is it because it's the wrong cord? Not enough juice?
  • walter_robis Jul 21, 2009
    I just pdf the manual and found that I must have the correct adapter.
  • 30 Answers
Yes... It shows on the back of the display how many amps it needs to run, the power supply should meet or exceed that number. it may say something like 4.16A
Posted on Jul 21, 2009
My polaroid fxm-1911c picture is distorted, sound distorted with loud buzzing when I try to utilize the tv signal input jack, also the dvd player doesn't work
Looks like there are some partial defects in the TV and might need attention of a qualified service technician. Anyhow, make sure that the input cable, RC jacks and sockets all do not have any loose contacts. Go through settings and ensure that every set up is as it should be.
Aug 02, 2012 | Polaroid FXM-1911C 19 in. LCD Television
Where is the AV button on the remote for the Poloroid 26 Inch LCD?
Hello
I believe that you have the orginal remote control of Poloroid FXM-2611C with you, and posts this solution
There is a 'square button' on the extreme left just below the "Disp" button marked 'TV'. Repeted press of this button, you can change the input mode to TV/AV.
To select different input modes use [input] button.
You can change the inputs to various modes. Refer to its user manual for details. OK
Apr 07, 2011 | Polaroid FXM-2611C 26 in. LCD Television
I have sound but no image
check your componet cords/hdmi unplug and plug them back in
Nov 20, 2010 | Polaroid FXM-1911C 19 in. LCD Television
I have a Sharp AQUOS LC-19SB14U 19' LCD TV that won't power on
The main power transistor in the power supply appears to have failed. It has also blown the fuse. Not a job for the DIY'er unless you have serious electronics experience.
Mar 08, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Have audio but no video image on tv.
Some Polaroid LCD TV's have a video mute function on the remote control (so you can play CD's and turn off the screen). If the video mute button does not restore your display, then the backlighting has failed and will need to be replaced. This is not an easy task, even if you can locate the replacement backlighting so you may want to find a local repair shop and get a quote on fixing the problem.
Jan 26, 2010 | Polaroid FXM-1911C 19 in. LCD Television
X2gen 19 inch monitor wont power on
Had the same problem with mine. First you need a volt meter (radio shack about $15). check the push in connector and make sure it has coming from it.
Place you meter on DCV for DC voltage, Then place one lead in the end of the plug in the hole. (will not fit all the way so will need to hold it there, Put the other lead on the shiny part of the plug. If you get a reading of 12 volts +/- 1 volt your good. Depending on which lead is were you may get a minus reading this is fine as if you switch your leads around it will go positive. you must have the cord plugged into the wall to do this test. You will not get shocked or anything as 12v is not enough to hurt you.
If you have the 12 volts the problem is in the monitor on the male plug or on the board. this takes more to fix and must take the back off the monitor and fix the connection or replace. I did this to mine and it is working right now.
Apr 10, 2009 | X2Gen MG19MY 19" LCD Monitor
Polaroid 2611-TLXB TV Logo
202 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
