What i have to do for permanent storage init error please give a perfect solution
  • 489 Answers
SOURCE: `permanent storage full error` what does it mean????
The internal storage system is full. You need to run the HP Web Jetadmin software and delete unnecessary files from the EIO disk device. When done, press the select button on the printer to return it to a ready state. You should be able to print small jobs yet as long as it doesn't require any temporary (or permanent) storage on the EIO disk.
Posted on May 27, 2009
SOURCE: my hp laserjet P4014n is
Hi! I will be glad to assist you in this issue.
Usually all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem.
Here is the link just incase you need more solution:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
Posted on Oct 26, 2009
  • 223 Answers
SOURCE: hp printer model M1522nf displaying permanent
HI,
This a formatter failure, sounds like the formatter went out while trying to do a hard reset or after updating the firmware,
Try doing a nvram:
Turn the printer off and hold the down arrow and the cancel button
Turn the printer on while holding the two buttons down
Continue holding until you see the permanent storage message and wait for the ready message to display
If this doesn't work call hp and tell them that printer is frozen and will not initialize, this is due to a formatter failure. If it has been less than 2 years since the purchase date then you will apply for a service note and will be able to have the printer serviced for free, Contact hp's tech support at 1800-334-5144.
Al
Posted on Jul 16, 2010
seeker5211
  • 1089 Answers
SOURCE: Please help me fix my
You need the printer serviced. The scanner/copier assembly at the top of the printer is in need of replacement. If it is still under warranty call HP. If not call a printer repair shop and get an estimate,
Posted on Jul 26, 2011
vinay229229
  • 1121 Answers
SOURCE: PERMANENT STORAGE INIT IN PRINTER HP 3050
If you have another same model printer, replace this formatter to another working printer check, no message? wait 10 minutes remove and install it back and check..If found same message replace formatter..
Posted on Feb 02, 2012
How to factory reset the hp pro 300 laserjet printer
1. Power down the printer
2. Press and hold the lower left hand corner of the screen
a. This is normally where the progress bar starts loading on the screen
3. Power on the printer
4. Release the left hand corner once the "Permanent Storage Init" message appears.
or alterative way
2. Press and hold the right arrow button on the navigational bar
a. This button will flash for a moment when the printer boots up
Jul 14, 2016 | HP Office Equipment & Supplies
Why is there permanent storage init error?
web search HP laserjet printer error codes
Sep 15, 2015 | HP LaserJet M1005 Printer
Please help me fix my scanner error 8 on my m1522nf HP printer. I have tried holding the right arrow and cancel keys at the same time on power ON to see permanent storage init but it did not work....
Jul 26, 2011 | HP LaserJet M1522nf Multifunction Printer...
My m2727nf try to load firmware now its giving me firmware corrupt error
Procedure Cold Reset
1. Turn off the product.
2. Simultaneously press and hold the Cancel button and the right arrow button (> ), and then turn on
the product.
3. Wait until the message Permanent storage init. appears, and then release the Cancel and right
arrow buttons.
When the NVRAM initialization process has been completed, the device control panel shows the
Ready message.
Let me know if this works. it should bring the printer back to factory settings.
Jul 15, 2011 | HP Laserjet M2727nf Multifunction Printer
79 error turn of and turn on
Try doing an NvRam on the printer (Hard Reset):
1. Turn the printer off
2. Press and hold the right arrow and the cancel button
3. Turn the printer on while still holding those buttons
4. Keep holding them until you see a message that say "permanent storage init"
This should clear that error message
Aug 05, 2010 | HP Laserjet M2727nf Multifunction Printer
Fax machine keeps giving error code 49
This could be a problem with the formatter board. Try an nv ram. Hold down the down arrow and the cancel button while the printer is off, turn the printer back on and continue holding the buttons down until permanent storage init is displayed.
Al
May 25, 2010 | HP LaserJet M1522nf Multifunction Printer...
HP laserjet 3330 Permanent Storage Init.
Switch of the printer press and hold down menu and cancel button turn on the printer keep holding these two buttons and turn on the printer.
As soon as printer display shows permanent storage init. release both the button.
May 11, 2009 | HP LaserJet 3330 All-In-One Printer
I have a LaserJet M1522NF printer and it does not receive some faxes and gives me a error 79 message on the display screen? can some one tell me what this is? i usually have to turn it off and turn it back...
Hello KIM !
Try doing an NvRam (Hard reset)
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
Feb 25, 2009 | HP LaserJet M1522nf Multifunction Printer...
52 scanner error problem
Perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
If this step does not resolve the issue, please repair/replace the printer.
Nikhil Gedam
Dec 11, 2008 | HP LaserJet 3050 All-In-One Printer
52 scanner error
Super NVRAM init
1.
if the above step does not resolve the issue, please repair/replace the machine
Nikhil Gedam
jasbo
jasbo
