My Siemens washing machine switches on the heating element without me selecting the program
Can I disconnect the thermostat without afeeecting normal operation and hw do I do that ?
  • 625 Answers
SOURCE: SMEG SA708X Oven Heater problem
thermostat must be getting a blast of cold air from the door being opened.
Posted on Sep 06, 2007
  • 3463 Answers
SOURCE: Creda Reversair Sensa Dry Tumble Dryer produces no heat.
There is only 1 heater element, and normally one thermostat.
they are located at the rear of the m/c, behind a removable panel.
If you are not sure whether it is the element or stat, join the two
wires togeher that go to the stat, if the heater then works, replace stat. if no heat, replace heater.
plz leave feed back for this solution.
Posted on Dec 17, 2008
  • 3463 Answers
SOURCE: Creda Simplicity 1000 Washing Machine not heating water
Make sure that you have not got the energy save button in operation, as this by-passes the heater, and will wash at the incoming water temp. It should not be showing green
If this is not the case, then the heater has probably failed.
To access the heater, you need to remove the top cover, remove the soap dispenser drawer, and undo the 4 screws securing the console panel to the top of the washer.
Pull off the timer knob, noting the position of it, and slide the console panel to the right, support it with something.
Remove wire cllip holding door seal to front of panel, and pull off the seal at the front.
Undo the screws securing the front panel at the top.
Undo 3 screws at bottom of front panel.
Lift front panel clear,and stand it at the right of washer, be careful of the wires still attached to the door lock.
At the bottom, in the center, you should find a black cover, remove that, and you will see the heater element.
You eally need a meter to test it for continuity, and or an earth fault.
Replace if faulty.
Please leave a fixya rating for my suggeted solution.
Posted on Feb 10, 2009
  • 3463 Answers
SOURCE: oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Posted on Jul 14, 2009
  • 154 Answers
SOURCE: Siemens stops without going into the spin cycle
when it stops is there and f:XX error code on the display? were XX is a number.
Posted on Jun 22, 2010
Why has my machine stopped heating
Some suggestions it can be a thermostat between the heating element and program clock, a slide contact safety problem by a broken hanger from the washing tub when the machine start to centrifuging it will disconnect some electrical circuits from the programclock for safety through increased range of motion can it happen by some Italian brands like indesit , or the heating element itself has its workinghours reached or an leaking problem that a fuse was broken by a problem by a damaged insulator by a bra strap that was come between the tube and the heating element.
Feb 13, 2017 | Washing Machines
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
Siemens washing machine displays error f-02
the heating element has failed
perhaps a temp sensor HTC
or the element has gone open circuit
this is caused because the machine did not get too the preset temp ...
Sep 06, 2014 | Siemens Washing Machines
No heat in dryer mode
In electric dryers, heat is generated by the heating element. The element is a coil of heating wire enclosed in a metal chamber. Electric current flowing through the coil creates heat and the air being pulled through the chamber absorbs this heat. If the element is defective then it will not heat. It can be tested with a multi-meter for continuity. Unplug the dryer and remove the front or rear panel to locate the element so it can be tested.
The high limit thermostat is a safety device mounted on the heating chamber and is designed to prevent the dryer from overheating when the exhaust vent is restricted. A restricted vent will cause the high limit thermostat to trip or activate, interrupting the circuit to the heating element or gas valve. The high limit thermostat is not designed to activate repeatedly like a cycling thermostat and will eventually fail causing a no heat symptom. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter. If there is no continuity then it will need to be replaced and the restricted vent system corrected as well.
Cycling thermostats control the temperature inside the dryer drum. They are designed to "cycle" the heating element on and off to maintain the correct amount of heat. Cycling thermostats are normally located on the blower housing or elsewhere in the internal airflow ducting. Over time, the cycling thermostat can become defective. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter.
Dec 02, 2013 | Splendide 2100 Vented Washer-Dryer
Water comes in on dry cycle
this could be normal, flushing the lint out of the drain hose. Mine does that as well. i find lint in the grey water tank. I live on my boatfull time. My heat has gone out now. cant determine if :its the thermostat or the heating element.
Oct 01, 2013 | Malber WD1000 Front Load Washer/Dryer
Cold Fill Siemens Does Not Get Hot
yes this could be the heating element or thermostat
May 29, 2013 | Amana ALW880WH Top Load Washer
Have siemens washing machine with cold supply in now running the whole cycle on cold is it the thermostat or the element
You must check the continuity of the element , check the wiring to the thermostat and the control panel.
Click on: Element
Jan 23, 2013 | Washing Machines
Hai hope you will answer me our washing mechine we bought 6 month before front loading and i do not want the heater the temep makes colour comes out and how to stop 30 or i put in feather touch all...
Hello Blessy, the problem is that the machine is pre programed tp give you a certain temperature depending on what program you select. If you disconnect the heating element, the timer will not move on in the program and it will stay in one place washing all the time. Basically, you need to purchase a machine that has a seperate temperature thermostat which you can manually set to low if you wanted.or a top laoder that has a hot and cold water inlet. You could just connect the cold water tap.
Sep 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Electricity goes off when machine start turning
it may be the motor if you unplug the motor then try again,if the power doesnt turn off then its the motor.also check for water leaks
Feb 28, 2008 | Siemens WXLS162 Front Load Washer
Machine fuses house RCD if a drying cycle is selected
Suggest you turn the power off, remove the top cover, diconnect the live and neutral connections to the dryer element (likely to be two of each flavour of connection if the machine has high and low dry settings). Pop a bit of insulating tape around the wire ends so you don't short anything out. Now try to put the machine through a drying cycle. If it works (albeit cold) without tripping the house power, you need a new dryer element. If the house power still trips, turn the power off again and without reconnecting the element wires, disconnect and tape the live and neutral wires from the blower motor. Again, try to run a drying cycle. If this stops the house power tripping, then it looks like a motor problem (though this would be quite unusual). If the house power still trips, you need to have a careful look at all the wiring between the main timer, the dryer timer, any hi/lo heat switch, the blower motor and the element with its associated thermostats and thermal cutouts (all located near the element on the air duct). Look in particular for chafes where wires go round corners, and where wiring crosses from the case to the suspended machinery in the middle of the machine. Pop any follow-on queries in the comments section of this question - I'll keep half an eye on it. A.
May 19, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
