Question about Garden
How to get rid of black soot like substance on leaves of citrus tree
4 Suggested Answers
SOURCE: I have a lot of black soot like substance that
Has to do with the detergent you are using is not completely breaking down the food materials being removed from the dishes during washing. I ran the dishwasher empty through a pot and pans cycle with maximum options and some bleach, Cleaned it to like new condition and from now on I use a detergent that has bleach in it. Cascade has several different products to cover this.
Posted on Sep 12, 2009
  • 739 Answers
SOURCE: After printing a photo the ink does not set on the
I'm going to ask the obvious question here. Are you putting the paper in with the right side up?
I haven't got any similar paper here at the moment but I do know that many glossy photopapers look 'glossier' on the back than on the front.
The back is generally impervious and so the ink just sits in its little spheres on the surface and evenutally dries out to a fine powder - the soot you see on your fingers.
If that is not the case post a reply and let's think about other possibilities.
Posted on Oct 05, 2009
  • 1244 Answers
SOURCE: audi a3 1.8t 99 keeps cutting out and backfires
you may want t check for vacumn leaks to the MAP before you go to the trouble of taking the convertor off also check the MAF i have a feeling the issues you are experiencing are more sensor component related than is catylitic convertor also the air idle motor in the injection system can cause the same problems if the air idle valve is stuck or the ports in the intake manifold are clogged
Posted on Jan 23, 2010
My lemon tree is full of fruit ,leaves are green with yellow marks on them,doesn't look healthy.What to do?
shortage of mineral in the soil
could be manganese, borax, or other items found in a citrus tree fertilizer
talk with a nursery showing them a few leaves
Jan 31, 2018 | Garden
Leaf curl on my Meyer lemon
Generally Meyer Lemon Trees need water every one to two weeks. ... If the leaves are drooping like they're too heavy for the branches, and turning dark brown or black the tree is getting too much water. If the leaves are crispy and dry or curl upwards this is a sign of under watering.
Meyer Lemon Trees: 7 Secrets for Loads of Fruit ' Fast-growing-Trees ...
Citrus Leaves Are Curling - What Causes Citrus Leaf Curl
https://www.gardeningknowhow.com/edible/fruits/citrus/curling-citrus-leaves.htm
Dec 29, 2015 - As far as fruit trees go, citrus tend to be the low-fuss member of the team; but when curling citrus leaves appear, you'll need to intervene. This article will help that. Click here for more info. ‎Citrus Fruit Brown Rot · ‎What Is Horticultural Soap · ‎What Are Psyllids: Tips On ...
Leaf Curl - Four Winds Citrus Problem Solver - Four Winds Growers
https://www.fourwindsgrowers.com/solving-common-problems/leaf-curl.html If the leaves on your dwarf citrus are curling, there are three common possibilities: Some insect pests will cause some leaf curl. In spring, aphids might do this on soft new leaves. ... Overwatering can cause leaves to curl or cup INWARD.
Why Are the Leaves on My Meyer Lemon Tree Curling? ' Hunker
https://www.hunker.com > ... > Garden & Lawn > Pests, Weeds & Problems May 6, 2010 - Pests. A number of insects can cause leaf curl in Meyer lemons. The most common and likely is the everyday whitefly, but aphids, citrus leaf miners, and mites are also common culprits. Insects are a larger challenge to manage than over-watering.
Meyer lemon Leaf curl Google Search
Jan 29, 2018 | Garden
How do I make my lemon tree healthy & bear fruit. I got rid of the bugs but tree looks unhealthy. No fruit for 3 years. Please help
Treat your lemon tree like an Olympic athlete - feed well and regularly, hydrate well and keep diseases at bay. Trim out dead wood and if leaves are yellow, mix some Epsom salts into your citrus fertiliser. When you mulch, stay away from the base of the trunk - citrus are prone to collar rot.
Nov 10, 2017 | Garden
True or false is the papaya the largest citrus fruit
false
papaya is not a citrus fruit
it is a fruit from a tall tree that is yellow or red ( depends on type of tree) hollow inside with hundreds of black seeds
the flesh can be eaten straight from the tree and if green hakes excellent chutney and can also be made into an ointment that helps heals sores
known in other parts of the world as a Paw Paw tree
Aug 26, 2017 | Homework
What caused fruit trees to have leaf curl
Hello May, please read these, they are a wealth of the info you need.. please mark as helpful...thanks
Fruit Tree Curly Leaf Treatment
Citrus Leaves Are Curling What Causes Citrus Leaf Curl
Leaf curl Wikipedia
Aug 01, 2017 | Garden
How to get ridmof Black soot like covering citrus trees
Is this actually soot, or like a fungus . Fruit leaves and or branches trunk.
Did this blow in on the wind rain.
Won't hose off?
Locate , contact county arborist take samples fruit and or leaves.
They diagnosed and iron deficiency looking at some oak leave..
Post a picture hear if you can maybe someone can I'd .
Are other type trees affected?
Jan 03, 2017 | Cars & Trucks
Borers in New Zealand Christmas tree Want to get rid of them
very common to have borers
treat it as any other ornamental tree
try Yates Nature's Way Citrus & Ornamental Spray
white oil will help
you have to treat the soil and the tree
cut away and dump as many affected limbs as possible
dont leave dead or affected cuttings lying around in the soil or in the yard
Nov 23, 2016 | Garden
My friend has citrus tree he waters the leaves and his tree have yellow leaves and dont look heathy. We live in BulLhead city arizona it gets very hot here in the summer
I have been there many times, the tree is heat stressed, heck it was 117F when we visited Laughlin last month.
Aug 19, 2016 | Garden
What is the cure for leaves curling on a lemon tree
http://homeguides.sfgate.com/leaf-curl-citrus-tree-37359.html
Dec 06, 2014 | Cars & Trucks
The tips of the leaves of my dwarf lemon tree in a pot are yellowing. what causes this and how can i fix it???
Dwarf citrus trees are especially suited for container growing as they can be kept at manageable .... Yellowing leaves most often indicate lack of fertilizer or poor drainage.
Also look here - check their trouble shooting
Growing Citrus in Containers
Oct 08, 2014 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
