Hello...Can I setup my system without a monitor? Access through network?
Bompani mashin washing no:Bo-5021ss
Posted on Jan 03, 2017
How do I set up remote live viewing on my I pad
you will need a compatible application(iCamViewer) to connect it to your camera or camera server for iPad and that allows you to configure streams and IP settings as as well as your username and password to access the camera.
If you are using static internal IP address so you have to do Port Forwarding Setup.
more technical help http://www.cctvcamerapros.com/iCamviewer-iPhone-App-Setup-Instructions-s/393.htmand router configuration http://www.techsupportrouter.com/support-for-d-link-router.html for your CCTV routers
May 07, 2014 | Computers & Internet
I have a toshiba A305-S6905 notebook with an A/G/N wireless adapter, but won't connect to an 802.11n network
Check the information that came with the router or access point to find out what connection mode the device is set to. The mode should be either ad hoc (when devices communicate directly without going through a router or access point) or infrastructure (when devices communicate by going through a router or access point). Make sure the setting in Windows for this network matches the setting on the device. To check this, follow these steps:
  1. Open the Command Prompt window by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking All Programs, clicking Accessories, and then clicking Command Prompt.
  2. Type netsh wlan add filter networktype=network type.
    Where network type is either adhoc or infrastructure.
  3. The router or access point is busy.
  4. The network you are looking for is set to not broadcast its network name (SSID).
  5. Your network administrator is blocking access to certain networks.
  6. The wireless network adapter is in monitor mode. Was this helpful?
Apr 18, 2012 | Toshiba A305-S6909 PC Notebook
Lexmark X4550 3 in 1. Although the wireless capacity has been loaded and activated it has ceased working and will not allow access.ie the flashing wireless connection light does not turn green just...
Try to reset the printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Wireless Setup > Reset Network Adapter > press check to confirm.
Re-launch the Lexmark Wireless Setup Utility to connect the printer to your network. If you have a firewall enabled, make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall. Also, place your printer where it receives excellent wireless signal quality and away from other electronic devices which can cause wireless interferences (e.g. cordless phones, microwave ovens, baby monitors, garage door openers, and other wireless electronics).
Jun 27, 2011 | Lexmark X4550 InkJet Printer
No puedo intalarlo
The Zero Configuration Utility built into Windows XP may vary depending on if you have installed Service Pack 1 or not.
Download Service Pack 1 here.
Without Service Pack 1
Step 1 Right-click on the two computer monitor icons in the system tray and select View Available Wireless Networks.
Step 2 Highlight your wireless network which is the SSID of your wireless network (if you are connecting to a D-Link router or access point it will be default) and click Connect.
Step 3 If you do not see your wireless network in the available networks box click on the Advanced button. Select Add and type in the SSID of your router or access point, uncheck this computer is connected in and ad-hoc peer-to-peer network, and then click OK.
With Service Pack 1
Please read here regarding Service Pack 1 and disabling the SSID Broadcast.
Step 2 Uncheck the Allow me to connect to this wireless network even though it is not secure box. Highlight your wireless network (if you are connecting to a D-Link router or access point it will be default), and click Connect.
How Do I enable Encryption using the Zero Configuration wireless utility?
Jan 18, 2011 | D-Link AirPlus Xtreme G DWL-2000AP...
Toshiba continues to reboot
The motherboard is faulty - there is nothing you can do to fix it. You could take it to a Toshiba service centre to get a quote, but it is likely to be nearly as expensive as a new one... sorry :(
Aug 20, 2009 | Toshiba Tecra A4-S313 Notebook
Hello , HP Proliant Server Problem.
Use a different monitor and connect it directly to the server, if problem persist you have a problem with the systemboard or microprocessor.
Jun 29, 2009 | HP ProLiant DL380 G4 36 GB Network Storage...
Wireless Network Setup
Install the Cisco Clean Access Agent software on your laptop. Contact your server administrator for the appropriate download for your operating system.
The software must be present to scan your system and send information to the Cisco Network Access Control device.
Feb 06, 2009 | Belkin (F5D7230-4) Router (587009)
Sony PCS-1 dont remember admin password
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN
Clear setup and FINISH
Bye Zamani Ali
azamani@iooc.co.ir
Nov 24, 2008 | Sony PCS-1 (PCS1) Video Conference
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
